noise and vibration reducment
  • alexv
19 Jan 2014 21:58 #101171 by alexv
noise and vibration reducment was created by alexv
I have some vibration inside the car which causes some noise , is there anything I can do ?
most of the vibration comes from the engine. a friend told me that replacing the engine mount will make it run like new.
what do you think?
  • JuanGuillie
20 Jan 2014 09:34 - 20 Jan 2014 09:44 #101225 by JuanGuillie
Replied by JuanGuillie on topic noise and vibration reducment
Very little info.... is it a standard Jimny, or modified, diesel (gas oil), what noise exactly, at all speeds or ... ?
Did you do a visual check on the motor mounts, rubber still in good condition?
Vibrations can come different way's, rims..., tires balancing leads missing..., bearings... and so on!
Could be some "death wobble problem".
Take a look at the Jimny Technical section : 3-th from above is the great "death wobble topic".
Succes! ;)
Last edit: 20 Jan 2014 09:44 by JuanGuillie.
  • jonesyba420
20 Jan 2014 09:39 #101229 by jonesyba420
Replied by jonesyba420 on topic noise and vibration reducment
doubt death wobble will cause noise unless its REALLY severe, what sort of vibration are we talking about? loose plastic trim vibration?something in the boot rattling together?when does the vibration occur?
Time to create page: 0.402 seconds
