Jimny lift ??
  • Mud slutt
17 Jan 2014 08:39 #100848 by Mud slutt
Jimny lift ?? was created by Mud slutt
I have measure to the top of the diver door handle is 1140cm & top of rear light is 129.5cm but is
That a 2 inch 2.5inch or 3inch lift I just don't know can anyone help
17 Jan 2014 08:51 #100849 by kirkynut
Replied by kirkynut on topic Jimny lift ??
It's a tricky one to answer because everyone's is different due to tyres etc.
See if you can find a truck in this thread with a similar height and tyres to yours - I know they don't all say what they are running but some have it in their signatures and others have a page in My Jimny telling you what they have done to their truck.
So you just have to have a bit of a read up unless anyone with the same size tyres as you and a simple lift with no body lift can help.
What size tyres are you running?
17 Jan 2014 15:43 #100880 by robs5230
Replied by robs5230 on topic Jimny lift ??
i'm needing the answer to the same question as i need to replace rear shocks. the answer appears to be remove a shock from bottom mount and measure at full extension and full compression. this measurement can be compared to new shocks supplied by martin at least. this will only give you the amount that the suspension is lifted by though. tyres and any body lift are not taken into account.
standard jimny - for now
  • markyp2000
17 Jan 2014 19:06 #100902 by markyp2000
Replied by markyp2000 on topic Jimny lift ??
The best way to mesure it is from the center of the wheel to the lip of the arch trim no matter what size tyre you have wether its flat or over inflated that distance stays the same
17 Jan 2014 21:08 - 17 Jan 2014 21:09 #100918 by robs5230
markyp2000 wrote: The best way to mesure it is from the center of the wheel to the lip of the arch trim no matter what size tyre you have wether its flat or over inflated that distance stays the same
never thought of that one. can you give me your measurements ? and presumably you don't have a body lift ?cheers rob
Last edit: 17 Jan 2014 21:09 by robs5230.
  • zuki andy
17 Jan 2014 21:11 - 17 Jan 2014 21:13 #100919 by zuki andy
Replied by zuki andy on topic Jimny lift ??
Bear in mind the arches have been trimmed on it. ( mud slutts)
Last edit: 17 Jan 2014 21:13 by zuki andy.
Time to create page: 0.655 seconds
