rear door card
- Thank you received: 1876
06 Jan 2014 11:41 #99341
rear door card was created by Lambert
Hi, does anyone know if there is a supplier of robust rear door cards for hard top jimny? At the moment ours is protected, in the loosest sense, with plastic film and I think something a little more strong may be a good idea. Anything spring to mind?
- JuanGuillie
06 Jan 2014 12:39 - 06 Jan 2014 12:44 #99351
by JuanGuillie
Replied by JuanGuillie on topic rear door card
You could make one in plywood, make it waterproof with some varnish and finish it off with a leather look type of plastic fabric.
Or give it a good coat of waterproof paint (both sides).
Put some sealing on the back of the panel and fix it with some screw's and washers to your back door.
Just a cheap fix, you also could get some rearpanel at a breaker (try j999pre).
Last edit: 06 Jan 2014 12:44 by JuanGuillie.
06 Jan 2014 15:57 #99373
Replied by Lambert on topic rear door card
I have yet to take the factory one off. Are you saying that behind the mouldings there's enough of a flat section to just fix a flat board to the door? I know there is the inner door release but we have yet to use that so that can be covered?
06 Jan 2014 16:40 #99377
by Halford
Replied by Halford on topic rear door card
the trim on the rear door comes off really easy ...
unscrew the lock pop-up button thing
then insert a large flathead driver in the lower trim slots and gently prise off (pop - pop)
then simply work from the lower right in a clock-wise driection popping the trim off
you shouldn't break any clips
now you can see what goes on
you could fit anything you like :blink:
The following user(s) said Thank You: helijohn
06 Jan 2014 16:57 #99389
Sweet. Cheers for that. Alloy plate here we come.
06 Jan 2014 17:56 #99410
by kirkynut
Replied by kirkynut on topic rear door card
Cheers Halford - I've been looking at putting some ply on mine as the plastic moulding takes up a bit of room and I want to put a shelf on it for putting my stove on when making a nice cuppa on the Lanes of our fine country - when not being verbally abused by Ramblers that is!
Time to create page: 1.154 seconds
