Yet another wheel spacer question!
- foggy
Done some forum searches, reading up and messaging some of you guys for advice but I'm still a little confused about which way to go.. So for the last time ( I promise) would you guys share your knowledge and experience on the above....
Wheel spacers...
Is 32 mm the max width for standard 205 70 15 without causing to many problems. (asking because I have seen 50mm spacers). I just want to take the wheels out to the arches (MOT LEGAL) but may fit larger tyres later. I dont want to be cutting, lifting etc at the moment...
Billet aluminium the best for strength?
Hubcentric spacers or not?
Spacers with fitted studs or the other type?
AND finally, would I get the same effect with off set steel wheels and if so in your opinion which causes less stress on the jimny....????
Guys thanks again, I know these questions have prob been asked a thousand times....
Regards
Foggy
- Poyner111
- TomDK
foggy wrote: Hi Guys,
Wheel spacers...
Regards
Foggy
What use do you intend with then?
For offroading, more than just the occasional geenlaning, I'd definitely get billet ones. Those Grayston's are way too flimsy for any real offroading.
- mc_nebula
TomDK wrote: Those Grayston's are way too flimsy for any real offroading.
I couldn't disagree more. There is nothing wrong with the Graystons from a strength perspective(in my opinion).
The graystons extend the studs, you have a stud extender which you screw over your original studs and torque up to the recommended setting. The metal casting sits over the top of the stud extenders and simply prevents them from coming loose. The cast "spacer" itself is not subjected to any abnormal forces or loadings.
If you have a 32mm spacer and a "modular" rim with an offset to achieve an equivalent spacing, the forces (and potential excess wear) are the same.
It is worth noting that the jimny front end is extremely susceptible to inaccuracies in tolerances, and that poorly toleranced parts can cause death wobble. Billet spacers are generally a tighter tolerance than the grayston ones.
- TomDK
You cannot tighten then up to specified torque, if you do so you're pretty lucky. Their're either overtightened or a bit loose, to fit in the hexagonal hole.
- mc_nebula
