Tyre pressure.
11 Dec 2013 00:52 #95373 by kirkynut
Replied by kirkynut on topic Tyre pressure.
Don't forget you lose ground clearance by airing down - so if you have deep ruts you have to make a decision on what's best.
  • jonesyba420
11 Dec 2013 06:38 - 11 Dec 2013 06:39 #95378 by jonesyba420
Replied by jonesyba420 on topic Tyre pressure.
Didnt mention that.......but thought it was obvious to anyone with atleast 1 brain cell :laugh: :laugh:
80 + views = no real usefull information given :(
Last edit: 11 Dec 2013 06:39 by jonesyba420.
  • polaarbear
11 Dec 2013 06:48 #95379 by polaarbear
Replied by polaarbear on topic Tyre pressure.
I use 30x9.5r15 Kumho KL71's on 15x7 steel wheels.. I have tubes inside the tyres as well to help keep the tyres on.
I usually set them to about 8-10 psi on sand and mud. Haven't had the tyres come off the beads yet but if they do come off the bead its not hard to pop them back on.
I agree if you let the tyres down you'll have less clearance that's for sure.. But with small tyres like mine I'm gunna get the diffs stuck whatever pressure I'm at..
11 Dec 2013 07:10 #95380 by Lambert
Replied by Lambert on topic Tyre pressure.
On my defender if I'm going rock climbing then I put my Michelin xpc 750s down to about 12psi but given it is a 90 pickup and I carry the least stuff for the trip I can it means it is relatively light, given the tyres are really for wagons and are 8ply they do deform over bigger rocks when twisted up but equally I only loose maybe an inch or less under the diffs.
  • TomDK
11 Dec 2013 08:23 #95394 by TomDK
Replied by TomDK on topic Tyre pressure.
This isn't exactly rocket science. Go out and give it a try. worst thing that can happen is the the comes of the bead, and you have to pop it back on.
  • Mister Stu
11 Dec 2013 09:57 #95399 by Mister Stu
Replied by Mister Stu on topic Tyre pressure.
Had a set of 235/75/15 saharas on my SJ and i coukd run them at about 8psi on standard wheels, they flexed around alot but never came off the rim and used to run 15psi for road
Time to create page: 0.188 seconds
