Battery
28 Oct 2013 22:32 #88402 by kirkynut
Replied by kirkynut on topic Re:Battery
helijohn wrote:
jonesyba420 wrote: Will any car battery work as long as you can get it to fit in the hole?I know the standard battery has small terminals so you might need to put new ends on the leads.
Generally yes but you ought to consider capacity in connection with charging rates.
@ Kirk
I've got a big Numax in the boot which is awesome and alot cheaper. It'll stay in the boot now I think.
Any issues with fumes at all?
No, it has two vent tubes on it which I have put out through the floor. The only fear is should it leak or go bang.
I have a scan gauge so can keep an eye on what it's charged with and it's so big in comparison to what a Jimny normally has that even if the regulator in the alternator went scuwith I don't think it could do it any harm.
The car's been on it's side and it didn't leak then and it's covered in a big thick rubber sheet to stop anything shorting across the terminals and should it go pop this would deflect the acid to stop it hitting anyone.
I'd rather not have a lead acid battery in the car but it's been fine and performs well.
  • helijohn
28 Oct 2013 22:51 #88408 by helijohn
Replied by helijohn on topic Re:Battery
kirkynut wrote: No, it has two vent tubes on it which I have put out through the floor.
Sounds good. Did you run a hot lead along the chassis to the engine bay?
Seems to me like rotting jack wells would be the ideal place to build a battery tray using new steel.
  • jonathan
17 Nov 2013 10:13 #91532 by jonathan
Replied by jonathan on topic Battery
found out that the Optima yellow top YT-B24RI fits a jimny and it has the small Japanese battery posts on it to , also i have found out a bit of useful info as i a now working for a battery company ,to make the battery last longer and perform better every 2-3 months give it a charge for 24 hours even a new one on a vehicle with a good quality charger , i use the CTEK MXS 5.0 from Sweden , as vehicles don't charge the battery up fully
  • agada
30 Mar 2020 08:52 #220460 by agada
Replied by agada on topic Re:Battery
can anyone suggest me a good car battery company?
  • TillymintDLG
30 Mar 2020 09:26 #220462 by TillymintDLG
Replied by TillymintDLG on topic Re:Battery
Have been using this company for easily over 20 yrs now...
Remember to check any battery you buy has Japanese slim posts as Jonathan pointed out!
www.tayna.co.uk/car-batteries/types/054/
  • jonathan
30 Mar 2020 12:20 #220468 by jonathan
Replied by jonathan on topic Re:Battery
The battery for the Jimny is a Yuasa YBX5057 and Groves batteries Ltd have stock and do online sales
www.grovesbatteries.co.uk
Time to create page: 0.216 seconds
