2000 Jimny Engine EFI wiring diagrams
  • Hooter
26 Aug 2013 06:24 #81040 by Hooter
I am in Australia and have a 2000 JSAFJB33V (first digits of VIN) Jimny, assume its a JB33V for short???
I have searched high and low on net, for engine wiring diagrams for this, (which is how I found this forum) and have only found (JB43V) SN413 which I assume is M series, which seems very different to mine. Mine has G13BB engine.
I dont know what Sn413 means or relates to, as i cant find this anywhere on vehicle etc.
Can anyone help, I mainly need the EFI wiring and ECM connections diagrams / pinouts
  • Hooter
26 Aug 2013 09:14 #81045 by Hooter
Replied by Hooter on topic 2000 Jimny Engine EFI wiring diagrams
OK, I have found on Wiki that SN413 is all Jimny's from 98 onwards
But the JB43 is the M13A engine which is what I thought
and the JB33 is the G13BB which is what i have
so I need wiring diagrams for G13BB engine
If its not cool for others to post links to diagrams on this forum, can someone let me know, in case Im breaki9ng rules or something..
Cheers
  • markyp2000
26 Aug 2013 10:18 #81048 by markyp2000
Replied by markyp2000 on topic 2000 Jimny Engine EFI wiring diagrams
Why are you needing one do you have a wiring fault or are you up rating your engine
26 Aug 2013 11:42 - 26 Aug 2013 11:43 #81052 by facade
There is a wiring diagram with the manual that you can download from the usual places the publication date is 2001, but it does show where the crankshaft sensor is which makes it a G series engine. It is the only known version (that you don't have to pay for), and doesn't cover pushbutton 4wd.
The wiring diagram is 99512_81A20_015.pdf
Put that into google B)
Last edit: 26 Aug 2013 11:43 by facade.
  • Hooter
26 Aug 2013 15:39 #81065 by Hooter
Thanks facade, Ive found that diagram before, but it is for the JB43, and the wiring at the ecm is totally different.
I am actually changing the ecm to a GM Delco unit which we have fully programmable software here, as we are hopping up the engine for offroad racing.
If I cant find diagrams, I will just have to pinout the harness with multimeter, its not that hard, just time consuming
Many Thanks anyway, will keep you posted.
  • markyp2000
26 Aug 2013 15:53 #81066 by markyp2000
Message this member see if he can help
www.bigjimny.com/index.php/forum/profile/728-rhinoman
Time to create page: 1.173 seconds
