Rocklobster conversions parts?
  • ne-crock
29 Jul 2013 13:39 #78534 by ne-crock
Rocklobster conversions parts? was created by ne-crock
Right i know this has been disscussed many times and i have searched but cant find my exact answer and trying to get everything ordered today so i can try fit it friday/saturday
I know the obvious like,
The lobster itself,
New mounts
Intermidiate prop
Front sj prop,
New hd bushes
What other things will i need?
Also i currently have a 25mm prop spacer on my front prop, with a 4" lift if i remeber correctly that will be too much spacer when i get my lobster?
Any bits i've missed would be much appreciated
Thanks
Crock
  • Smoggy
29 Jul 2013 14:05 #78538 by Smoggy
Replied by Smoggy on topic Rocklobster conversions parts?
Keep the spacer Mike it will probably come in handy for your mini prop from the gearbox.
With a 4'' lift the other props should fit straight on.
  • ne-crock
29 Jul 2013 14:12 #78539 by ne-crock
Replied by ne-crock on topic Rocklobster conversions parts?
Would 25mm not be too long for the mini prop?
Also what oil?
I've found two answers ep90 or sae 75w-90? Before i go order the wrong one, which one is right?
Is it true it holds 0.8 litres?
  • Smoggy
29 Jul 2013 17:14 #78550 by Smoggy
SAE 75W-90 0.9litres. The 25mm spacer should be about right for the mini prop mate. I am sure mine is 25mm on a 4.5'' lift.
  • RichiesJimny
29 Jul 2013 18:15 #78555 by RichiesJimny
Replied by RichiesJimny on topic Rocklobster conversions parts?
Smoggy wrote: SAE 75W-90 0.9litres. The 25mm spacer should be about right for the mini prop mate. I am sure mine is 25mm on a 4.5'' lift.
Your mini prop spacer was 12.5mm Mike, I needed an 18mm spacer with my Rockwatt mount so maybe different mounts require different spacers.
I don't have any spacers on the front or rear props with a 3 inch lift (which lifted it 4 inches)
You'll also need a speed sensor mounting bracket and a toothed ring for the output shaft, if the lobster has been fitted to a jimny already it might come with those if not Rockwatt or ORA sell them.
  • ne-crock
29 Jul 2013 18:19 #78557 by ne-crock
Also do the mini props vary in length?
I dont know if it does have the speed sensor, does this mean my speedo wont work without it?
Cheers richie, i'm using mikes old mount, so i presume i'd need a 12.5? Its an ora one
Time to create page: 0.140 seconds
