Which engine should i go for
  • zain
15 May 2013 08:21 - 15 May 2013 08:23 #70755 by zain
Replied by zain on topic Which engine should i go for
i shall post pics of the engine i am having for now too . and would you be kind enough to tell me whether i would get some extra power and fuel efficiency in result of such swap .
with regards
Last edit: 15 May 2013 08:23 by zain.
  • zain
23 May 2013 08:23 #71428 by zain
supergaz wrote: The G16b engine is no bigger in size and will bolt straight in. That will give you the best gain without the headache. All I think you need is the original sump pan and oil pickup.
I didnt get this part . would any body kindly elaborate as to i need those parts as new or the parts of old engine would work
23 May 2013 11:55 - 23 May 2013 11:57 #71451 by Rhinoman
If its a Baleno engine then you must use the 1.3 sump but you will need to cut the baffling a little to get clearance. The oil pick-up pipe will need to be modified to fit the 1.3 or you will need to cut and shut the 1.3 and 1.6 pipes. The GV engine is supposed to be a simpler swap but you may need to mdoify the sump if you don't have enough clearance to the diff.
You get a good boost in power and torque but it is not a straight swap, there are a few write-ups on the swap around the web. You need an adapter plate and you will need to modify/replace/move one engine mount.
Last edit: 23 May 2013 11:57 by Rhinoman.
  • Cider
23 May 2013 12:19 #71452 by Cider
Replied by Cider on topic Which engine should i go for
Hi
The GV engine is a much easier swop you`ll won`t have to switch the cam shaft" unless your fitting it into a rag top" or sump/oil pick up
I have a write up on this forum but not sure how to post a link to it on here
Time to create page: 0.250 seconds
