Newbie
  • GuardianAngel
12 May 2013 22:36 - 12 May 2013 22:37 #70586 by GuardianAngel
Replied by GuardianAngel on topic Re: Newbie
Brake lines are fiddly on any motor but on a J quite easy because its high up. Get some ramps to make it a "luxury" job :lol:
As for the engine, it works best between 3 - 4k rpm which seems to be the sweet spot.
Last edit: 12 May 2013 22:37 by GuardianAngel.
  • supergaz
12 May 2013 22:37 #70587 by supergaz
Replied by supergaz on topic Re: Newbie
Welcome to Bigjimny ;-)
14 May 2013 20:37 #70723 by dirtydogz
Replied by dirtydogz on topic Re: Newbie
Welcome to Big Jimny.
The front soft top roof folds as in the photos.
Hope this helps you.
2002 JLX Soft Top B)
Jimnybits 2" lift +Pro Comp ES1000 shocks.:) Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
  • UKDAN
03 Jul 2013 23:30 #76056 by UKDAN
Replied by UKDAN on topic Re:Newbie
Biasmechanic wrote: Thanks for the welcome guys. I live in the outskirts of Eastbourne.
2. Having done plenty of research before buying a jim i know the engines are fairly tough and reasonably revy. Obviously being only a 1300 it needs to be pushed to get up to speed but is the engine tough enough to cope with being taken to the red line reasonably often? I know its no race car but it would be nice to get where I'm going!
Thanks for any help!
You can red line it but when you do, you can watch the fuel needle move in the opposite direction & quickly too.
Dan
  • helijohn
04 Jul 2013 14:25 #76112 by helijohn
Replied by helijohn on topic Newbie
Hello. I am sure you are going to enjoy your Jimny. It was the little Suzukis that pulled me into owning nothing but 4x4s. I had a Landrover 2a and it nearly put me off for life. So MX5..........watch out. ;)
  • jonathan
07 Jul 2013 11:12 #76331 by jonathan
Replied by jonathan on topic Newbie
welcome but why do you need to red line it ,i have been in the motor trade as a tech since 1978 only boys red line just because they no no better ,if it is to be red lined you need to keep the oil clean and changed regualy so that is half normal service time and you need a good grade of oil and do not red line unless the engine is at normal engine temp (hot)
Time to create page: 1.784 seconds
