long range tank??
- reaper
01 May 2013 20:04 #69825
by reaper
Replied by reaper on topic long range tank??
But it would need to be made by a real fuel tank manufacturer
I for one wouldnt put my name to one . ..
- JerseyJimny
01 May 2013 20:20 #69829
by JerseyJimny
Replied by JerseyJimny on topic long range tank??
Hmm... As long as its made by a coded welder and then pressure tested for leaks it should be fine...
as it isn't structural or high pressure you don't even need to be coded!
The general engineering company I work for (only small) make a few tanks every now and again for heating oil and we repair a load of tanks for boats etc
As long as they pass a pressure test then they are safe to use
- ozjoel
02 May 2013 09:29 #69857
by ozjoel
Replied by ozjoel on topic long range tank??
same same, making a petrol tank here is simple.
dont need to be an rocket surgeon.
just need it certified by a coded boily and get a safe load pass cert done (which i can do at work)
making the tank isnt the ordeal, its the easy bit, mocking one up and all the trauma associated measurements will be the hard bit.
- reaper
04 May 2013 10:33 #69969
by reaper
I am a coded welder and make high and low pressure vessels in both ally and stainless for trains and aircraft use , both have to be vigorsly tested so i know im capable , my point is i wouldnt want to build on for anyone as if anything went wrong in use i would be inbjail for a long long long time
- ozjoel
04 May 2013 11:42 #69973
by ozjoel
thats goes for any product anybody makes for the consumption of joe public mate.
as long as the vessel you make holds fuel and is tested correctly and is certified, your covered, at least thats how it is here, what could possibly go wrong with a professionally made tank from a competent technician?
as long as nobody tries to use one for some sort of petrol smoking bong apparatus, it just has to hold fuel etc,
hopefully i will have one done in the next 18 months and others could use the plan as a basis of cheers or geers i spose.
- ozjoel
07 May 2013 09:21 #70188
by ozjoel
back of a tow truck?
Time to create page: 0.187 seconds
