brake pipes on jimny
  • Jackdelves
01 Apr 2013 07:44 #67499 by Jackdelves
brake pipes on jimny was created by Jackdelves
hi there
as im new to the jimny got loads of little jobs to do .noticed brake pipes could do with tiedeing up bit rusty can you get a complete kit any were .or do you just get them bit by bit.oh also got a bit of under body rust i would like to treat to slow it down any easy way to do it.like if i spray some thing on it.
thank you all great to here from you all.
  • GuardianAngel
01 Apr 2013 09:06 #67504 by GuardianAngel
Replied by GuardianAngel on topic Re: brake pipes on jimny
If you are mechanically capable then making your own lines is the best way. If your not confident pay a qualified mechanic.
Get a reel of copper/nickel brake line (wont rust), some brake unions (M10) and a flaring kit (that can do double ended flares). Halfrauds do all of these.
Take the old lines off one by one and use then as a template to form the new ones. Becareful on sharp bends not to kink the pipe. I use a secured metal bar to gradually work the pipe into a smooth bend
I had my J professionally undersealed, as its a messy job, by Rustmaster. Comes with a 5 year guarentee and free annual top ups.
  • Jackdelves
01 Apr 2013 10:51 #67515 by Jackdelves
Replied by Jackdelves on topic Re: brake pipes on jimny
thank you great advise.im game to do any mechanical job .have just done new king pins and bearings and seals. new disces and pads.
cheers .
01 Apr 2013 14:42 #67538 by kirkynut
Replied by kirkynut on topic Re: brake pipes on jimny
You need flaring tools etc. When mine needed doing the cost and bother made it not worth doing myself. Then my Mrs BMW needed brake pipes doing too, I came to the same conclusion again. I'm confident I could do it well but it looks a little fiddly and without a ramp tedious.
So it depends on not only ability but also how much you like doing things for yourself.
The following user(s) said Thank You: Jackdelves
Time to create page: 0.278 seconds
