Removing rear seats
  • markyp2000
06 Mar 2013 19:24 - 06 Mar 2013 19:28 #64774 by markyp2000
Replied by markyp2000 on topic Removing rear seats
rogerdadodger wrote: Under the cover that goes around the seatbelt catches there are two bolts that go down through the seat hinge into the floor on the seatbelt side of the chair . Then on the other there's a stud that sticks out from the wheel arch, if you pull the seat foam to one side there's a nut that needs undoing from the end of the stud. Then there are two bolts under each seat base & the carpet just pops on with poppers!
Good luck :)
There are 4 bolts under the cover 2 for each seat and there is no need to undo the nut on the stud just unvelcro the lower outer corner of the back and undo the 12/14mm bolt remove seat back then remove the nut on the bracket
Last edit: 06 Mar 2013 19:28 by markyp2000.
  • gus2000
06 Mar 2013 19:56 #64784 by gus2000
Replied by gus2000 on topic Removing rear seats
With a good carpet.
transport the dog
to load a lot of baggage
Gustavo
07 Mar 2013 04:59 - 07 Mar 2013 16:24 #64825 by Halford
Replied by Halford on topic Removing rear seats
click here for 2005+ rear seat removal ...... your's will be similar
click here for my rear load space project
Last edit: 07 Mar 2013 16:24 by Halford.
The following user(s) said Thank You: gus2000
  • Teds Jimny
07 Mar 2013 15:53 #64852 by Teds Jimny
Replied by Teds Jimny on topic Removing rear seats
That's a neat job there with the wood!
  • Teds Jimny
07 Mar 2013 15:55 #64853 by Teds Jimny
The plastic which fits over the seat belt anchor point is loose but I can't see a join in it to take the plastic off, or do I have to snap it off? :(
07 Mar 2013 16:28 - 07 Mar 2013 16:34 #64854 by Halford
:unsure: not sure which bit you mean, your's may be different to mine (2007)
but here's a pdf guide to remove the rear trim (which houses the rear belts)
liking Gustavo's dog ;)
Last edit: 07 Mar 2013 16:34 by Halford.
Time to create page: 0.569 seconds
