Upholstery and seat repairs
  • VAXXi
31 Jan 2013 14:09 #60395 by VAXXi
Upholstery and seat repairs was created by VAXXi
Well, searched and searched - haven't found a similar topic.
The driver's seat has developed a gash on the exterior lateral support area (presumably due to repeated rubbing when getting inside the car). There's a thin metal plate right in the middle, and two pieces of sponge on each side. I assume it's not the same sponge, so the metal blade didn't cut the sponge - the two pieces are different in colour:
[IMG
[IMG
I assume the side sponge somehow got away from the metal blade, leaving it exposed. Is there a way to remove the upholstery in order to put the sponge back to its right position ?
  • Dave cc
31 Jan 2013 22:32 #60475 by Dave cc
Replied by Dave cc on topic Upholstery and seat repairs
Not a great deal of help to you as your location says Romania but i had the same problem on my Toyota Hilux took it to a local company who did bus seat repairs he took the cover off sewed in a new panel and repaired foam all for £30 bit of a bargain in my eyes maybe you cAn find someone local to do the same for you
  • VAXXi
01 Feb 2013 11:02 #60523 by VAXXi
Replied by VAXXi on topic Upholstery and seat repairs
I was thinking if it's possible to do a quick fix (like remove the covers), but seems it's way above my tailor skills :( off to search for a reconditioning company then... thanks!
  • Dave cc
01 Feb 2013 13:21 #60537 by Dave cc
You can take the covers off mate no big deal just lots of faffing about with clips and trim bits could stitch repair the fabric and bond and shape some more foam over the metal before re fitting cover
Time to create page: 0.187 seconds
