Wobbly O2
  • Jimnyash
26 Jan 2013 18:33 #59735 by Jimnyash
Replied by Jimnyash on topic Wobbly O2
Was shims on mine too (had the wheels balanced at 3 places).
Got them from the BigJimny online shop (very quick delivery) and did it within 30 minutes.
Made a big difference.
  • supergaz
26 Jan 2013 19:50 #59751 by supergaz
Replied by supergaz on topic Wobbly O2
JivingDaddy wrote: Thanks supergaz & reaper.
I'm on the borders of London & Kent. Bit of a treck to Lancashire, but a great idea. Thanks.
Anyone know a good reliable mechanic locally that I can trust with the wife's O2?
Markyp2000 is a mechanic on here down that area, might be worth sending him a message.
26 Jan 2013 20:32 #59757 by fast forward
Replied by fast forward on topic Wobbly O2
i have the same problem on my 02 54 plate . king pins ! now also needing brake pads and discs so can fit all new at the same time , good job reaper lives round the corner nudge nudge :blush:
if you cant go round it go over it ! or vice versa ?
The following user(s) said Thank You: JivingDaddy
26 Jan 2013 20:35 #59758 by fast forward
just kidding mate ! :laugh:
26 Jan 2013 20:39 #59760 by pgatensuk
Replied by pgatensuk on topic Wobbly O2
I have read on here somewhere that the alloy wheels fitted to the O2 can also cause this problem and it was a known fault. I think the wheels can warp?? I am sure someone on here will correct me.
The dreaded Jimny death wobble is a most annoying fault that most owners have experienced at sometime and can be difficult to fix.
Not sure JivingDaddy if you know, but all soft tops where built in Spain and the hard tops come form Japan. There is talk of differences in build quality, but I'm not convinced.
I have had wobble on both the Jimny's I have owned. After checking wheel balance; wheel bearings and king pins. Check discs for warp (this fixed my problem in the past).
If you fit bigger tyres and wheel (heavier), this can also make the problem worse.
Shims have also been reported many times as a fix.
If you have checked all the above and still no joy, fitting a steering damper will also help (this worked on my current Jimny).
Good luck and let us know what fixed the problem.
Paul
2005 Jimny VVT soft top
2002 Jimny Soft top - Sold
2007 Triumph Tiger 1050 - Sold
2011 Kawasaki W800
2002 Twin boys
2001 Kerry Blue Terrier - RIP
2012 GoldenDoodle
  • reaper
26 Jan 2013 21:31 #59767 by reaper
Replied by reaper on topic Wobbly O2
fast forward wrote: i have the same problem on my 02 54 plate . king pins ! now also needing brake pads and discs so can fit all new at the same time , good job reaper lives round the corner nudge nudge :blush:
No problem mate if you need a hand pop round . . . . .and i can show you where sponnie lives :-)
Time to create page: 0.303 seconds
