rear shock brackets that rattle
  • reaper
25 Jan 2013 17:59 #59542 by reaper
rear shock brackets that rattle was created by reaper
I noticed that after fitting some rear shock re-positionrs that due to having to leave some slack on the mounting bolt that they rattle like mad
Even with the mounts drilled and the through bolts were used they still needed some play to let them rotate so the rattle was still there .
Well i mentioned this the james (j999pre) and he had the same problem this was what i came up with thanks to james for the old shock that i stole the eyes from :-)
Now the mounting bolt can be tightened right up just as you would a shock ....no more rattle that in turns means no dead spot on your shocks :-)
25 Jan 2013 18:05 #59543 by j999pre
Looking good.
Time you started knocking them out. I know someone that would want a set ;)
Grey pick up Jimny
  • reaper
25 Jan 2013 19:47 #59552 by reaper
Replied by reaper on topic rear shock brackets that rattle
If you have the eyes im happy to make some up for you :-)
  • reaper
26 Jan 2013 15:35 #59696 by reaper
So had alot of pm's about these and although im happy to make them for anyone that supplys the eyes they are very easy to make yourself
Needed
2x shock eyes
Some 50x50x5mm box section or some plate to bend into a U section , or some standard brackets with the small eyes cut off
Thats it just get some weld and new bushes on there :-)
  • markyp2000
26 Jan 2013 15:57 #59702 by markyp2000
Replied by markyp2000 on topic rear shock brackets that rattle
Rhino ray sells them its a very good idea
  • reaper
10 Feb 2013 21:15 #62035 by reaper
So he does marky and not a bad price either wish i had seen those lol
Time to create page: 0.172 seconds
