Anyone else's Jimny not like the cold?!
17 Jan 2013 15:07 #58387 by minibbb
gilburton wrote: Definately the alternator belt. It's surprising the amount of drag the generator creates when charging the battery and you have the heater/wipers/lights all switched on.
As a temporary measure you can tighten it up but I would recommend a new belt if the surface of the belt is below the pulley edges or appears worn in any other way.
As for misting up this has been a long standing complaint of mine re the jimny. There is no through flow ventilation in the rear. My old 98 Jimny was terrible and I had hoped my 08 Jimny would solve it with the air con but not quite.
It helps a lot of course but the rear window and rear side windows still mist up.
That's very helpful thanks mate!! Is it an easy job to change the alternator belt? Is it likely to just snap? Looks like ill need the car this weekend!
17 Jan 2013 15:13 - 17 Jan 2013 15:15 #58388 by gilburton
see how much slack you have at the moment but the old rule of thumb used to be around 1/2" deflection at the longest part of the belt without force.
www.bigjimny.com/index.php/forum/6-jimny...0035-alternator-belt
I started off high and worked my way down ever since :-)
Last edit: 17 Jan 2013 15:15 by gilburton.
17 Jan 2013 15:24 #58391 by kirkynut
I'd change the alternator belt, it's probably gone harder with age so moisture causes it to slip easier.
The moisture causing the frozen screen could come from your shoes in view of how wet it's been everywhere recently. It's hard to solve if the car's not used daily to heat it up and get it out the windows.
I've seen these little bags like hesian sacks in Landrover mags that soak up moisture to stop this. Not sure what they call them or where you'd get them.
  • MalcolmB
17 Jan 2013 17:39 #58399 by MalcolmB
Replied by MalcolmB on topic Anyone else's Jimny not like the cold?!
Hi...
Change the alternator belt ASAP!
I ignored the squeaking for a week or so and the belt snapped! Alternator light on, temp gauge rising rapidly. I was only a couple of miles away from home so I nursed the Jimny back OK apart from popping the expansion tank top off and ejecting half the coolant just as I pulled up!
I got both belts for about eight quid at my local Motor Factors (Speedo at Crook - highly recommended) You might as well change both while you're on. And get a spare pair.
I really advise taking the radiator out - it's much easier and it'll probably be quicker than trying to fiddle around behind the radiator cowl and leaving flesh all over the place.
Cheers
Malc
17 Jan 2013 17:40 #58400 by minibbb
Ill deffo try and get it changed I think.
Is it likely to just go suddenly though?
18 Jan 2013 20:12 #58543 by minibbb
Took the jimny into the garage today, turns out the lamda sensor has gone and the power steering belt looks worn so both being replaced on Monday. Hopefully will solve the problems!
Time to create page: 0.240 seconds
