very small gap between wheel and track rod
- jimnybob
08 Jan 2013 22:52 #57583
by jimnybob
very small gap between wheel and track rod was created by jimnybob
has anyone else got this problem? basically i rolled underneath the jim this afternoon and couldnt help but notice that the gap between the rim of the front wheels and the bracket on the knuckle joint (where the hub joins the track rod end/steering rack) is very close. like i cant get my little finger through :dry: one side looks like its touched the rim at somepoint. if someone could let me know of a fix or if this is a common thing
- phippj1
09 Jan 2013 10:55 #57610
by phippj1
Replied by phippj1 on topic very small gap between wheel and track rod
HI, yes it is a common issue. I have fitted wheel spacers to my car, only 10mm ones but this has given clearence now that is acceptible.
- little jimny
09 Jan 2013 17:53 #57634
by little jimny
Replied by little jimny on topic very small gap between wheel and track rod
For me with a standard car on standard Jimny wheels (steels or alloys) all is well, but clearance was very tight when I used a set of Vitara alloys (they were ET20) - so tight in fact that clip on weights fouled the steering arm and I had to remove them and get the wheels rebalanced with stick on weights!
- jimnybob
09 Jan 2013 20:32 #57653
by jimnybob
think this is going to have to happen! dont like the idea of it being so close :dry: how much am i looking at for spacers??? anyone got some their getting rid of?
Replied by jimnybob on topic very small gap between wheel and track rod
phippj1 wrote: HI, yes it is a common issue. I have fitted wheel spacers to my car, only 10mm ones but this has given clearence now that is acceptible.
- ZookFastback
09 Jan 2013 21:03 #57658
by ZookFastback
Replied by ZookFastback on topic very small gap between wheel and track rod
What offset do your rims have? My Jimny has heaps of space with Sunraysia Rims.
- jimnybob
09 Jan 2013 21:23 #57664
by jimnybob
how do you measure that? is it the same as J's
Time to create page: 0.172 seconds
