'89 Jimny Loss of four wheel drive.
  • Yorkshirejimny
01 Jan 2013 16:22 #56789 by Yorkshirejimny
'89 Jimny Loss of four wheel drive. was created by Yorkshirejimny
No longer have four wheel drive when I connect using manual lever, does anyone have any idea of cause and possible cost of repair/ remedy?
Cheers
  • supergaz
01 Jan 2013 18:24 #56810 by supergaz
Replied by supergaz on topic '89 Jimny Loss of four wheel drive.
Can you hear a click sound from the front hubs when selecting 4H or 4L? The vac system is tempermental so many of us fit manual hubs.
Welcome to BigJimny.
  • Yorkshirejimny
01 Jan 2013 19:57 #56819 by Yorkshirejimny
Replied by Yorkshirejimny on topic '89 Jimny Loss of four wheel drive.
Thanks for your info SuperGaz. It doesn't make a clicking sound but maybe need to think about fitting manual hubs... any idea of a rough guide to cost? Thanks you for your advice
YorkshireJimny
  • supergaz
01 Jan 2013 20:17 #56821 by supergaz
You either have a loose pipe or a leak in the vac pipes or grease blocking the hole into the hub. Best to look in the bigjimny shop at hub adapter rings or also try jimnybits , both will have the parts required for the conversion.
Time to create page: 0.160 seconds
