JIMNY SEAT BELTS
  • tx200
14 Dec 2012 11:20 #55498 by tx200
JIMNY SEAT BELTS was created by tx200
i posted a topic on here about what seems to be a jimny problem, front seat belts not returning. today i spoke to a guy from securon the seat belt makers and he said he's sure i need a set of 500/15 £24.95 each ) for my car. and to get rid of the air bag light , put a 2.5 ohm resiter across the conection and it will go out.
does this info look as if this will do the business. now i'll have to work out how to remove the old belt system. im sure some one will know how to remove the interior to do this.
TX200
  • goatboy
14 Dec 2012 11:26 - 14 Dec 2012 11:29 #55500 by goatboy
Replied by goatboy on topic JIMNY SEAT BELTS
Like was said in the other topic most Jimny seat belts are slow going back. If you search on here its been covered a few times and nobody seems to have fixed it. I'm sure if you want to put new belts in that would help but it might be a more fundamental problem in the design.
I can't see how this would affect the airbag light though.
Putting a resistor across anything to do with the airbag is effectively cheating the system into thinking its working so be very very careful.
I recently had the airbag light on and depending on the year you can actually get the dash to flash up what the error is (its in the workshop manual how you do it). on mine it was the slip ring behind the steering wheel that had broken. I got a scrap one, checked it and replaced it and the light is now off...
Still the seatbelts don't return properly though....
Last edit: 14 Dec 2012 11:29 by goatboy.
  • adamatdraycott
14 Dec 2012 15:10 - 14 Dec 2012 15:13 #55513 by adamatdraycott
Replied by adamatdraycott on topic JIMNY SEAT BELTS
If you are talking about the two front seatbelts not returning... its very common in Jimny's
The guides are very close together to stop the belt twisting... and the general grime on the belt transfers to the guides clogging them up!
If you look carefully between the guides and the belt, you will probably see a black sticky substance. Scrub/scrape this away with a small screwdriver/toothbrush. You may need to force the belt to one side.
My belts sometimes wouldn't return, and came close to being shut in the doors a few times :angry:
Last edit: 14 Dec 2012 15:13 by adamatdraycott.
  • Allen
14 Dec 2012 16:23 #55515 by Allen
Replied by Allen on topic JIMNY SEAT BELTS
Mate get it plugged in, A diagnostics check should tell you where the problem is, I had a warrior the other day and it was disc behind the steering wheel (squibble).. I'd have check probably first before guessing..
14 Dec 2012 16:43 - 14 Dec 2012 16:46 #55516 by dirtydogz
Replied by dirtydogz on topic JIMNY SEAT BELTS
Pull the seatbelts right out wash with hot water and some washing-up liquid till you got all the grime off, then hook the seatbelts around opposite seat and let them dry.
2002 JLX Soft Top B)
Jimnybits 2" lift +Pro Comp ES1000 shocks.:) Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
Last edit: 14 Dec 2012 16:46 by dirtydogz.
  • GuardianAngel
14 Dec 2012 22:23 #55550 by GuardianAngel
Replied by GuardianAngel on topic Re: JIMNY SEAT BELTS
Yep I have shut my belt in the door several times. Bloody annoying!
Sent from my GT-I9100 using Tapatalk 2
Time to create page: 0.243 seconds
