body lift info
  • winter
03 Dec 2012 20:21 #54771 by winter
body lift info was created by winter
eyup who done a 2" body lift
are there any things you have to ex-end when doing a 2" lift iv got brake lines ex-ender is there anything eles ????????? befor i start thanks guys
  • nezzy55
03 Dec 2012 20:59 - 03 Dec 2012 21:02 #54777 by nezzy55
Replied by nezzy55 on topic body lift info
You need to extend your steering rod, that goes from the collum to the steering box, also need to extend transfer box lever and make a little extender bar for the 2 flexis that bolt to the chassis
Last edit: 03 Dec 2012 21:02 by nezzy55.
  • Skinhead
03 Dec 2012 22:47 #54790 by Skinhead
Replied by Skinhead on topic body lift info
I didnt extend anything exept brake pipes, just losen both ends of the steering arm thing an make sure you tighten them back up after. You will need to cut the hole abit bigger for the transfer gear leaver so you can put it in 4low, i just put 2 slits about 30mm an folded the metal undernieth.
03 Dec 2012 22:56 #54791 by dirtydogz
Replied by dirtydogz on topic body lift info
I think this is what nezzy55 ment by a little exender bar.
2002 JLX Soft Top B)
Jimnybits 2" lift +Pro Comp ES1000 shocks.:) Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
  • Skinhead
03 Dec 2012 23:24 #54797 by Skinhead
dirtydogz wrote: I think this is what nezzy55 ment by a little exender bar.
Oh ye, i unbolted that and never got round to making a bracket for it, it seems solid enough :ohmy: :huh:
Time to create page: 0.247 seconds
