Speakers
  • Tadpole
10 Nov 2012 18:15 - 10 Nov 2012 18:54 #52813 by Tadpole
Replied by Tadpole on topic Speakers
Two in the footwell one each side & yes you can 'upgrade' for the rear ...
I found a link hope this is of some help to you ...... ;)
www.danbp.org/w/Installation_of_the_rear..._on_the_Suzuki_Jimny
Last edit: 10 Nov 2012 18:54 by Tadpole.
  • ZookFastback
11 Nov 2012 00:53 #52848 by ZookFastback
Replied by ZookFastback on topic Speakers
Those two 4" speakers in the front footwell can be replaced with 5" quality speakers, makes a big difference. When I did mine I put in a splitter and ran two x 1" ribbon tweeters up above the seatbelt anchorage point so that they are near ones' head. That way old bugga's like me get to hear everything nice and clear :)
1" ribbon tweeters
The rear speakers are removable and click into leads at the back. Amp is mounted on back of box and wiring is quick-remove too.
11 Nov 2012 08:40 #52851 by Mescort
Replied by Mescort on topic Speakers
I have mounted 2 subs behind the seat
G16B, Doug Thorley Header, Trail-Gear 6,5:1 Transfer, Front 28 Degree CV propShaft, Rockwatt crawler box kit, Zanfi 2" springs, Zanfi 10° + 10mm Front Radius arm, Caster Correction Bushes rear, Adjustable Panhard, Bilstein 5100 Shocks, Dotz dakar 15x7, goodyear duratrac 235x75x15, warn M6000
  • Paul4x4
11 Nov 2012 08:54 #52852 by Paul4x4
Replied by Paul4x4 on topic Speakers
I have four 4" speakers in the standard holes(component system at the front), tweeters on the dash in the corners of the windshield and a 10" flat active subwoofer under the drivers seat.
  • JerseyJimny
11 Nov 2012 22:35 #52965 by JerseyJimny
Replied by JerseyJimny on topic Speakers
Mescort wrote: I have mounted 2 subs behind the seat
They are quote small subs... do they do a good job? Also where did you get them from? I guess they are flush mount?
Thanks everyone :)
  • markyp2000
11 Nov 2012 22:45 - 12 Nov 2012 19:41 #52969 by markyp2000
Replied by markyp2000 on topic Speakers
i like the rear 1/4 triming where did that come from
Last edit: 12 Nov 2012 19:41 by markyp2000.
Time to create page: 1.801 seconds
