1.6 vitara to Jimny
  • russell
07 Nov 2012 13:12 #52564 by russell
1.6 vitara to Jimny was created by russell
Hey I was wondering if any 1 had fitted a vitara 1.6 into a Jimny I recently perchased a 1.6 to fit in my Jimny the block looks like it will bolt straight in pretty much but when you look close there's alot of differences electrically more than anything I'm a plant and heavy machinery mechanic so it's no issue I was just on a advice hunt
  • Dave cc
07 Nov 2012 13:26 #52565 by Dave cc
Replied by Dave cc on topic 1.6 vitara to Jimny
8 valve or 16 valve Vitara engine ? if its a 8 valve you need to get piston pockets put in.
Other than that more or less nut and bolt job mix and match sort of fits but only sort of :unsure:
I reckon better just to swap jimny head onto block saves a lot of sodding about but you will need green baleno injectors or will run like crap
  • russell
07 Nov 2012 17:20 #52570 by russell
Replied by russell on topic 1.6 vitara to Jimny
Wow so the 1.3 head fits ? That makes things simpler if it dose
  • Dave cc
07 Nov 2012 22:40 #52618 by Dave cc
Yep bolts straight onto a vit 16v block just need to use the 1600 belt and cam cover and a 1600 head gasket
  • russell
08 Nov 2012 14:15 #52644 by russell
That sounds pretty good saves a lot of whirring problems and mess. Gear box wise looking at the back of the bit box once split from the t box the rear of the box looks very similar was wondering if I can fit the rare case of the Jimny box to the rear of the vit box because the vitaras seem alot easyer on the engine at cruzing speed in the higher gears other wise even tho it's a 1.6 it will still be revving its nuts off at 65! Do you know of anywhere online or any body who has a set of these " green injectors"?
  • Dave cc
08 Nov 2012 22:45 - 08 Nov 2012 22:46 #52677 by Dave cc
Dont think Vit and jimny boxes are interchangable in any way but may stand corrected.
Upping the size/dia of your tyres will help your road gearing but will do nothing for your off road gearing and will just put more strain on the clutch
Last edit: 08 Nov 2012 22:46 by Dave cc. Reason: spelling
Time to create page: 0.433 seconds
