Jimny02 Alloy Wheels v Steel Wheels
  • P.I.T.A.
01 Nov 2012 17:18 #51876 by P.I.T.A.
Jimny02 Alloy Wheels v Steel Wheels was created by P.I.T.A.
I have been advised by Suzuki that the Jimny02 has the awful wheel/steering wobble because they changed from steel to alloy wheels to make it look 'pretty'. As the wobble is so hard to effectively repair without causing possible further issues (costing more....) is it not possible to just change the wheels back to steel ones? Or would this mean making modifications for them to fit.....
  • little jimny
01 Nov 2012 17:29 #51877 by little jimny
Replied by little jimny on topic Jimny02 Alloy Wheels v Steel Wheels
They're a straight swap - no mods required. Or you could try the five spoke alloys (I'm assuming you've got the three spoke wheels at the moment)
  • P.I.T.A.
01 Nov 2012 17:40 #51878 by P.I.T.A.
Replied by P.I.T.A. on topic Jimny02 Alloy Wheels v Steel Wheels
Thank you for that - relieved re the straight swap! All I can hope now is the garage will stop messing about, I can get the car back on the road and then.....look for someone to teach me off-roading! Thanks again.
  • MWells
01 Nov 2012 19:13 - 01 Nov 2012 19:16 #51889 by MWells
Replied by MWells on topic Jimny02 Alloy Wheels v Steel Wheels
You might have to change the wheel nuts as i believe the taper or shoulder is different for alloys and steels, although i could be wrong. just found this which explains the reasoning.
Mark
Last edit: 01 Nov 2012 19:16 by MWells.
  • markyp2000
01 Nov 2012 21:33 #51900 by markyp2000
Replied by markyp2000 on topic Jimny02 Alloy Wheels v Steel Wheels
you will have to change all the nuts
  • reaper
01 Nov 2012 22:23 #51905 by reaper
Replied by reaper on topic Jimny02 Alloy Wheels v Steel Wheels
Its not the wheels or the tyres its the bearing shims that have worn
Time to create page: 0.189 seconds
