Not very good in the wet on roads?
- Trillian
21 Sep 2012 08:44 #48449
by Trillian
Not very good in the wet on roads? was created by Trillian
I'd like to start by saying I'm a pretty sensible driver, I don't drive excessibly fast but in the same respects I don't drive like an octogenarian. I'd say I was a carefull and cautious driver.
However, I've spun the Jimny 3 times in the wet now! Well, ok, one of the times I didn't actually spin it, I just felt it go a little out of control round a corner whilst it was raining but managed to straighten again. These were all at low speeds.
Is there something wrong with my Jimny or is this normal? I've driven variety of different cars and occasionally when I get a powerful hire car I'll drive it like I stole it but I really do take care of my car!!!
- ZookFastback
21 Sep 2012 09:06 #48450
by ZookFastback
Replied by ZookFastback on topic Not very good in the wet on roads?
You need quality highway tyres to get any decent road-handling out of the Jimny. I run a good set and have off-road tyres for playing. It all depends, I guess, on what you are planning to do with the Jimny. If it is mainly bitumen then get road tyres with big grooves and wide sylphs but if it is a good mixture of on/off road then buy M/T tyres and just take it easy in the wet on the roads. Jimnys are somewhat top heavy and the narrow track, short wheelbase set-up does not contribute anything to road-holding ability.
One soon learns to drive within the Jimnys' capabilities.
- p1ngu32
21 Sep 2012 09:12 #48451
by p1ngu32
Replied by p1ngu32 on topic Not very good in the wet on roads?
I've never really had a problem with the jimny tailing out unless provoked, but my cornering speeds are probably a bit lower due to MT tyres and a lift. What are your tyre pressures at? the jimny only needs some where around 25 psi.
- Keefe
21 Sep 2012 09:46 #48452
by Keefe
Replied by Keefe on topic Not very good in the wet on roads?
If you've got Duellers on, swap them for something better.
The bog standard Jimny I drive in Cyprus has them on and it's a nightmare if the tarmac is damp.
I'm waiting while they are worn down before changing them. It has no roof so isn't driven in the rain. When I say damp tarmac, what I mean is when someone is running a hose pipe and the water runs out onto the road, especially on a hill and on a bend. It will slide the back out at less than 2500rpm in 3rd, going up hill on a bend if it's wet. Luckily, the understeer pre-warns you a little. LoL
Well that's what I find, I would say, "Change the tyres."
K
K
- Trillian
21 Sep 2012 10:00 #48453
by Trillian
Replied by Trillian on topic Not very good in the wet on roads?
Yeah I have deulers on, I thought Bridgestone were decent tyres! Will I have a similar issue when the snow arrives? Although I suppose during the snowy season I can switch to 4WD.
As far as I am aware I shouldn't drive in 4WD at all on tarmac due to transmission wind up, but someone was saying this is only on cars pre-2005, is that right or are they talking rubbish?
- Keefe
21 Sep 2012 10:28 #48458
by Keefe
I'm not sure if it's ok on the post 05 cars to drive in 4wd on dry tarmac, mine's a 2001 over here and a 2000 in Cyprus.
To me, and this is only my opinion, the Bridgestones feel as if they have too much 'nylon' in the rubber or perhaps just too hard a compound, I don't know.
I've had Bridgestone Potenza's on my 'normal' car and I found them incredible in any conditions. Mind you, they were worn out after 8000 miles of heavy going. LoL!!
I've never used the Duelers in snow, perhaps fortunately, so can't comment on them.
I would say to change them when you can.
Kumho KL71's are good??
K
K
Time to create page: 0.187 seconds
