How to remove the handbrake cable in 5 seconds!
- ZookFastback
18 Sep 2012 01:59 #48282
by ZookFastback
How to remove the handbrake cable in 5 seconds! was created by ZookFastback
How to remove the handbrake cable in 5 seconds... and not by cutting
After you have removed the brake shoes, bring the end of the brake cable out and slide a 12 mm ring spanner over and push to close the prongs. Cable then slips out of brake base and the 12mm ring spanner falls off. Simple. :woohoo:
Pic of the removed handbrake cable showing how the 12mm ring spanner slips up and closes the prongs for easy removal.
Well, it may not be a world-shattering idea, but it works quickly and simply and I am proud of having discovered it myself, even if every mechanic in the world might have known about it already
18 Sep 2012 06:16 #48285
by j999pre
Grey pick up Jimny
Replied by j999pre on topic How to remove the handbrake cable in 5 seconds!
Nice work. Seems quicker and easier than the jubilee or zip tie methods I have used.
Grey pick up Jimny
- vitara_mad
18 Sep 2012 09:48 #48290
by vitara_mad
Replied by vitara_mad on topic How to remove the handbrake cable in 5 seconds!
thats a great tip as its a real pita to get them out by using a screwdriver to push the prongs 1 by 1 & pulling & twisting
- renard38
18 Sep 2012 11:30 #48297
by renard38
Replied by renard38 on topic How to remove the handbrake cable in 5 seconds!
so goooooooooooooooooooooooooooood !!!!!!
- Johnniehec
- Thank you received: 56
18 Sep 2012 18:36 #48319
by Johnniehec
Replied by Johnniehec on topic How to remove the handbrake cable in 5 seconds!
Yeah, well done, the simplest tips are always the best!!
John.
John.
- myers647
18 Sep 2012 21:11 #48333
by myers647
Replied by myers647 on topic How to remove the handbrake cable in 5 seconds!
top idea that mate,last time I did it I used a tie wrap.
Simples
Thanks
Simples
Thanks
Time to create page: 0.238 seconds
