lower front end
  • stevedumptruck63
09 Aug 2012 06:16 - 09 Aug 2012 06:24 #45765 by stevedumptruck63
Replied by stevedumptruck63 on topic Re: lower front end
markyp2000, what a reply!!!!!!
when i purchased the jimny it already had all the kit on.
i was not sure which size spacers to fit that is why i put the post on,to see if anyone had fitted a specific size spacer,
what i didnt expect was a rant from someone telling me i had bought the wrong stuff,
but hey i suppose we all like a rant at someone now and again. steve :evil:
Last edit: 09 Aug 2012 06:24 by stevedumptruck63.
  • reaper
09 Aug 2012 06:36 #45766 by reaper
Replied by reaper on topic Re: lower front end
Mine has done the same mate , just bought 4 2" saucers so if you want 2 let me know
  • reaper
09 Aug 2012 06:38 #45767 by reaper
Spacers lol dam auto correct
  • markyp2000
09 Aug 2012 16:58 #45793 by markyp2000
Replied by markyp2000 on topic Re: lower front end
hi steve
wasnt ment to be a rant if you had said it had a lift kit when you brought it i wouldnt have said most of what was said like i said mine had a lift lit when i got mine it sagged more than a grannys t*t and it already had 2" spacers in it is yours sagging on one side or is it even drop on the front cos you may find if you put a pair of spacers in it the same size it may still sag low on the drivers side you may need say a 2" on the drivers side and may be only a 1" on the passangers
  • stevedumptruck63
09 Aug 2012 18:20 #45800 by stevedumptruck63
i have had a good think about it today,and think iam going to go for exactly what you have sugested
2" drivers side and 1" passenger side and see how it looks. steve :evil:
  • markyp2000
09 Aug 2012 18:37 #45802 by markyp2000
measure from the center of each hub to the bottom of the wheel arch in a stright line and take the mesure ment then try jacking the body up with 2 jacks one on ether side till you think the hight is good and remeasure the hight then take away the lowest mesurment on ether side then that should give you what sort of size spacer you need
