help , MOT fail
- vitara_mad
03 Jul 2012 21:59 #43482
by vitara_mad
its a easy job don't take long & no special tools needed & no press
Replied by vitara_mad on topic Re: help , MOT fail
rooster wrote: ah thought the bearings would take longer than that so thanks for that. do you need a press to do the bearings ?
- rooster
03 Jul 2012 22:26 #43483
by rooster
Replied by rooster on topic Re: help , MOT fail
great , i think i will do that myself then. i did look on jimny shop first but did not see them , i will look again. thanks
- rooster
03 Jul 2012 22:43 #43484
by rooster
found them . will order tomorrow pm. hope i can get them before the weekend?
- markyp2000
03 Jul 2012 23:14 #43486
by markyp2000
Replied by markyp2000 on topic Re: help , MOT fail
if the exhaust had a major leak it would have failed mauy be on the lambda reading id double check the exhaust may be for now put a exhaust bandage on it from halfords if all your king pins bolts come out ok and you have all the tools to hand quickest iv done one side was half an hour and while your in there clean out the cv and refill with new good quality grease may be look at some marine grease its repels water better that normal stuff hope this bit helps to
- rooster
04 Jul 2012 17:28 #43508
by rooster
UPDATE ....... picked up the jim removed rear bumper to have proper look at the silencer , guess what ..a hole that looks like you have pushed a pin through it and on the top by the tail pipe the outer skin has started to seperate from the seam and blowing sightly. emissions test result PASS. spoke to another mot centre and was told that due to th wording on failure sheet (rear exhaust has major leak of exhaust gases) it should not of passed emissions due to the fact they would not of even tried it. taking it to 2nd mot centre tomorrow for second opinion.!!!!
- goatboy
04 Jul 2012 19:17 #43510
by goatboy
Replied by goatboy on topic Re: help , MOT fail
Mine looked like that so I decided to change it. When I took it off it had a huge hole on the top towards the back didn't sound too bad either. Could be worse than it actually looks
Time to create page: 0.182 seconds
