Drivers side Vacuum hub permanently locked?
  • markyp2000
04 Jun 2012 18:13 #41745 by markyp2000
Replied by markyp2000 on topic Re: Drivers side Vacuum hub permanently locked?
Mala43B wrote: When I select 4H the 4WD light on the dash comes on although does not flash.
I know for sure the left hub locks and unlocks OK but the right one will not unlock.
I can hear a hissing noise when I remove the right hub (still in 2H) so as soon as I replace the hub, it locks even though I have not selected 4H.
that may mean the control valve in the engine is letting some vacuum through take both the pipes off on the drivers side front trailing arm and see what the hubs do then thay should both relese then start the car leave in 2h and put your finger over the pipes that go to the car body not the axle and see if it suckes on your finger a little if so the valve is f*~ked and letting vacuum through then such on the pipes on the axle and see if you can get the hubs to lock whilst jacked up turn the prop then both front wheels should turn ethe back or forward
04 Jun 2012 18:16 #41746 by facade
facade wrote:
Most likely you have a fault with the vacuum system.
Sounds as though the "lock" vacuum solenoid is leaking/stuck.
With the engine running in 2wd try disconnecting the rubber pipes at the swivel housing one at a time, and see if they are sucking. They should not be. I bet one is and it keeps applying the hubs.
Time to create page: 0.147 seconds
