16 inch wheels and tires on Jimny
  • manualejo
07 May 2012 14:53 - 07 May 2012 14:55 #39492 by manualejo
Replied by manualejo on topic Re: 16 inch wheels and tires on Jimny
A jimmy always runs nice B). Thought mine is a pavement princess with 225/60 tire profile it does not struggle and they are way more clearance to brakes and lighter also as there is less Tire and more rim, mine are like 28" street tire btw my jimmy is vvti
Last edit: 07 May 2012 14:55 by manualejo. Reason: Mistakes
  • adamjimny
07 May 2012 15:15 #39497 by adamjimny
Replied by adamjimny on topic Re: 16 inch wheels and tires on Jimny
Changing to 16's only give more clearance if you go bigger tires.
Other wise they will be the same diameter
If all you want it more clearance then just go bigger tires on the 15' wheels as it can be harder to get small mud tires in 16"
I went to 16's as i went to landrover size tires and worked out cheaper than equivelant in 15'
sent from my Samsung Galaxy S2 using Tapatalk
  • reaper
07 May 2012 15:28 #39498 by reaper
Replied by reaper on topic Re: 16 inch wheels and tires on Jimny
Or you could get some adapter/spacers and use landrover wheels :)
  • manualejo
07 May 2012 15:31 #39501 by manualejo
Yes that's true, really harder to find, I don't worry as I have other set of rims with mud three wich I don't need as I never get stuck, nothing hardcovers thought
  • adamjimny
07 May 2012 15:54 #39505 by adamjimny
The only reason to change to 16" wheels is if its easier/cheaper to get the diameter of tires you want otherwise its pointless.
  • myers647
07 May 2012 18:25 #39519 by myers647
Replied by myers647 on topic Re: 16 inch wheels and tires on Jimny
No eBay APP ID and/or Cert ID defined in Kunena configurationHi mate if your after some of these wheels Iv just come across some in Peterborough.
Time to create page: 0.237 seconds
