getting a wire through the bulkhead
- little jimny
28 Mar 2012 17:32 #36527
by little jimny
getting a wire through the bulkhead was created by little jimny
I need to get a wire through the bulkhead on the passenger side. Is there an easy and obvious way of doing this, or am I going to have to remove a load of internal trim and lift the carpets to do it?
28 Mar 2012 17:41 #36529
by Halford
The following user(s) said Thank You: little jimny
- Johnniehec
- Thank you received: 56
29 Mar 2012 09:55 #36559
by Johnniehec
Replied by Johnniehec on topic Re: getting a wire through the bulkhead
Yep I used that route too, it's the bonnet release cable.
John.
John.
- suzuki jimny fella
30 Mar 2012 17:06 #36614
by suzuki jimny fella
Replied by suzuki jimny fella on topic Re: getting a wire through the bulkhead
how have you guys run a live 12v wire through bulkhead please
30 Mar 2012 19:09 - 30 Mar 2012 19:17 #36623
by dirtydogz
2002 JLX Soft Top
Replied by dirtydogz on topic Re: getting a wire through the bulkhead
There is an ideal place in the passenger footwell. If you pull the mat back and look in the centre, towards the top you will see a wire going through towardds the centre console. Try get something in that grommet which will allow you to pull your wires through. I taped mine to the screwdrive in the image. It pops out near the brake lines to the left of the passenger wheelarch in the engine bay.
Hope this helps from JonathonMarshall
Attachment S7002456.JPG not found
Attachment S7002454.JPG not found
2002 JLX Soft Top
Last edit: 30 Mar 2012 19:17 by dirtydogz.
- Johnniehec
02 Apr 2012 09:54 #36746
by Johnniehec
Dirtydogs, you would have been better with the fuse on the other side, as close to the battery as possible, if it does rub through here it's gonna melt.
John.
John.
