tbox lever bending
- Cider
21 Mar 2012 09:30 #36113
by Cider
Replied by Cider on topic Re: tbox lever bending
Hi
Start at the ball end straighten the first kink out,then bend the second bend to around 130 degree angle
then at this time the whole shaft will need to be rotated 90 degrees as in the top picture.
The next bend is about 90 degree angle,best test fit as you`ll need to put a slight bend to keep the stick away for your seat
hopefully you`ll won`t be to far from the mark
Cheers
Pete
Cheers
Pete
08 Jul 2012 21:40 #43765
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Re: tbox lever bending
Hi was the lever in the picture above for a jimny with a body lift our not?
A really useful post thanks.
Grey pick up Jimny
- Cider
09 Jul 2012 20:36 #43843
by Cider
same lever used before and after a 2 inch lift without any problems
- Paul4x4
09 Jul 2012 20:46 #43845
by Paul4x4
Replied by Paul4x4 on topic Re: tbox lever bending
Anyone used a press to cold bend it? I'm not a huge fan of heating things up red hot, and play around with them, so I'm gonna try using a press, or then I just use the cut and weld method....
10 Jul 2012 19:40 #43905
by j999pre
Grey pick up Jimny
A friend and I did mine today. We decided that the lever is fairly soft and proved this by straightening it out in a large vice quite easily.
Then we bent it using oxy to something like the picture in this thread and tinkered with it from there.
Its all done now and the standard jimny gaiter fits a treat.
Couldn't be happier.
I just need to give it an outing now and try the low range.
Grey pick up Jimny
Time to create page: 0.147 seconds
