1 fault with the Jimny.
  • little jimny
02 Jan 2012 20:32 #29804 by little jimny
Replied by little jimny on topic Re: 1 fault with the Jimny.
I'm half tempted to hack it to bits and put a double din stereo in there
03 Jan 2012 05:55 #29820 by facade
Replied by facade on topic Re: 1 fault with the Jimny.
wanderinstar wrote: if you do anything more than 50 you can get wobbles.
Something is wrong with it, likely worn out kingpin bearings and dust seals.
They do get blown around but without wind they drive straight (unless you have an uncorrected lift fitted)
  • wanderinstar
03 Jan 2012 15:04 #29858 by wanderinstar
Replied by wanderinstar on topic Re: 1 fault with the Jimny.
Back to the clock problem.
Cant find these screws.Do you have to take the radio out first?
Ian.
03 Jan 2012 16:04 #29866 by facade
Right under the black part at the very bottom of the dash there are 2 pozidrive screws.
Remove them, and then take the ashtray out, and remove the 2 self tappers upwards through the metal ashtray guide plate at the seat end.
The black part of the dash wrenches outwards at the bottom, but won't come out with the radio cage still fitted, so this has to be removed as well.
  • wanderinstar
06 Jan 2012 18:09 #30166 by wanderinstar
Well,Ihave taken 2 screws out of the bottom, 3 out of the ashtray aperture.But it still seems to be stuck like S***to a blanket.Rang a dealer up and he said he thought there were 2 more screws behind the radio.But then he mentioned some clips somewhere.
Grumpy 22 where are you,when i need you.:)
  • supergaz
06 Jan 2012 21:23 #30186 by supergaz
Replied by supergaz on topic Re: 1 fault with the Jimny.
Look at the bottom of the top of the radio in the middle is a upside down screw on the trim, then this will be loose once the screws in the ashtray are removed, then with the trim off there is 4 screws holding the whole radio/clock unit in.
It's the easiest radio i've ever removed out of 1000's.
