Tip for oil filter removal
- goatboy
26 Sep 2011 07:40 #22554
by goatboy
Replied by goatboy on topic Re: Tip for oil filter removal
I have never come across an oil filter I can undo by hand, ever when I have only tightened it by hand in the first place.
I always used the screwdriver punched through method but its nasty if you are doing it underneath or space is tight so I purchased one of these.
www.machinemart.co.uk/shop/product/detai...ench?da=1&TC=SRC-oil filter
Little bit fiddly to use but works reasonably well...
Anyway back on topic, sandpaper is a good tip!
26 Sep 2011 15:03 #22583
by facade
Replied by facade on topic Re: Tip for oil filter removal
I've got one of those, but I can't make it work :blush:
I use the strap and lever type if I have overtightened it and it won't undo by hand.
28 Sep 2011 16:24 #22724
by kirkynut
Replied by kirkynut on topic Re: Tip for oil filter removal
I use the type with the three legs that close in.on it and grip where there is room, such as on a Jimny. You can't lose with those.
- teafortwo0789
28 Sep 2011 17:09 #22729
by teafortwo0789
Replied by teafortwo0789 on topic Re: Tip for oil filter removal
I use a 'Laser Tool' which is like a pair of pliers which grip the filter and being slim will get into most places, also they provide a good feel so you know how much torque you are using.
I've used to use the old screw driver through the filter, too messy but convenient..
I've used a strap which grips the filter and is rotated by using a ratchet, clumsy and won't get into tight places.
Also used a chain with a handle which hooks and tightens, but still slips and not user friendly.
So far the pliers are best for me.
- ZookFastback
28 Sep 2011 17:47 #22734
by ZookFastback
Replied by ZookFastback on topic Re: Tip for oil filter removal
I've always just hand-tightened my filter with a smear of oil and removed it by hand too. The filter is easy to get at and no probs.
28 Sep 2011 17:52 #22738
by dirtydogz
2002 JLX Soft Top
Replied by dirtydogz on topic Re: Tip for oil filter removal
2002 JLX Soft Top
