Headlight wiring/adding highbeams
- Adamski
VAXXi wrote: Definitely fuse the wire going from battery to relay as close to the battery terminal as possible. 2 x 55 W = 110 W, at 12 V it's around 9.2 amps in total not counting wiring/connector losses. A 10 A fuse should be ok in this case, as both lights are powered by the same cable. If not, use a 15 A one.
To understand better what you're doing there: you're splicing into the existing headlight wiring to control a relay on pins 85/86. When you turn on the beams, they'll switch the relay on allowing current to flow between pins 30 and 87, supplying power to the projectors.
Oops forgot to add the 2 lights together! Good job vaxxi stepped in. 4.58amps per light x2 = 9.2amps.
I should have remembered this as I wired my 4 spot lights in not long ago at a total of just under 20 amps.
- Dutchjimny
Is it possible to use the projectors in 2 ways? Seperate with a switch and/or with the original highbeam handle ?
- VAXXi
- renard38
