procomp 75 mm lift. jimny bits
- Sandez
05 Jul 2011 21:17 #18626
by Sandez
Replied by Sandez on topic Re: procomp 75 mm lift. jimny bits
Hope you have deep pockets because once it starts...
- zammit
06 Jul 2011 02:20 #18628
by zammit
Replied by zammit on topic Re: procomp 75 mm lift. jimny bits
Hey sandez
Thanks heaps for your imput on the suspension it's greatly appreciated.
And is making me slowly make up my mind.
Could you give me a price on what you paid for your suspension and
What was included?
Would be greatly appreciated
Cheers
Zanmit
What was included?
Cheers
Zanmit
- Sandez
06 Jul 2011 05:54 #18633
by Sandez
I ordered the 2" lift (Same price as 3"), generic steering damper, rear shock repositioners and caster correction bushes all delivered for around $820 after conversion.
How to work out the price is to add all the items to your basket, change the shipping to Australia, it will give you the total down the bottom in £'s. Times the total by 1.5 and it will roughly give you the AUD price at the current exchange rates. Based on that, the lift kit with shipping will cost $555. Given the kit weighs the most and shipping is based off weight, adding other items will only increase the shipping by marginal amounts if at all.
The lift kit is just like in the picture, there are also small little packets containing some small tubes that fit into the inside of the bushes for each shock that reduce the hole to match the bolt that holds it in (if that makes sense).
Hope that helps.
I'll hopefully have a full write up of my build soon showing all the steps I've done for each mod so others can follow and learn from.
Hope that helps.
- darthloachie
06 Jul 2011 05:59 #18635
by darthloachie
Replied by darthloachie on topic Re: procomp 75 mm lift. jimny bits
don't forget the extended brake pipes
- Sandez
06 Jul 2011 06:44 #18641
by Sandez
Definately, considering it would be free shipping with the kit and is a must for 3"
- zammit
06 Jul 2011 09:12 #18645
by zammit
ah yes! thats good i just done a few calculations and for:
3 inch kit
brakelines
shock mounts
panhards
and castor bushes
it ends up being just over a grand. which is really cheap but then cause its tipped over it means i have to pay 10% gst and 10% import duties
so i thinki may try and source a few things locally, or do 2 orders
3 inch kit
brakelines
shock mounts
panhards
and castor bushes
Time to create page: 0.168 seconds
