Jimny suspension lift, help please!
- quatermass
02 Jun 2011 19:58 #17247
by quatermass
Jimny suspension lift, help please! was created by quatermass
:huh: Hello Im new to the site and im looking for some advice on a 2" suspension lift.
What do i need to do/change/alter. The car is going to do light off road and the odd greenlane, nothing too bad.
Cheers guys.....colin
- Strek
02 Jun 2011 21:04 #17253
by Strek
Replied by Strek on topic Re: Jimny suspension lift, help please!
Hi, and welcome. What you need to do is to use the search function on this forum. You will find a lot about this topic. With 2" I changed the brakelines (longer) and caster corrected bushes in the radius arms up front.
- Johnniehec
- Thank you received: 56
03 Jun 2011 12:13 #17272
by Johnniehec
Replied by Johnniehec on topic Re: Jimny suspension lift, help please!
Hi Welcome, Ditto what Strek says, assuming you're fitting + 2ins springs and shocks, you'll need to fit the longer brake flexy hoses (
www.llama4x4.co.uk
) first or at the same time especially at the back (otherwise you can't get the axle to drop far enough to get the un compressed springs in). I haven't got round to fitting my caster correction bushes yet but be prepared for a bit of wandering and tramlining if you don't.
John.
John.
The following user(s) said Thank You: quatermass
- quatermass
03 Jun 2011 18:00 - 03 Jun 2011 18:01 #17282
by quatermass
Thanks Guys, great help!
Ive got a pair of KAP front arms ready to go on (castor sorted) so i think it will be okay when done.
Ive read that there is a little problem with the rear shock mounts but there are mods avalable to sort things out, is it worth doing??
Also would the panard rod need to be tweeked :huh:
Thanks again guys, hope to hear from you again soon...col
Replied by quatermass on topic Re: Jimny suspension lift, help please!
Last edit: 03 Jun 2011 18:01 by quatermass.
03 Jun 2011 18:11 #17283
by dirtydogz
2002 JLX Soft Top
Replied by dirtydogz on topic Re: Jimny suspension lift, help please!
Just fit some rear shock brackets for martin.
www.bigjimny.com/store/index.php/jimny-p...k-brackets/p_14.html
Attachment thumb_bracket21_2011-06-03.jpg not found
2002 JLX Soft Top
Time to create page: 0.214 seconds
