Front and Rear Recovery Points
- Bannerbrother
19 May 2011 14:38 #16560
by Bannerbrother
Front and Rear Recovery Points was created by Bannerbrother
How strong are the towing eyes on the jimny would they make good recovery points, or do they need altering?
has anyone got any pics of what they have done?
- paulnb57
19 May 2011 18:06 #16570
by paulnb57
Replied by paulnb57 on topic Re: Front and Rear Recovery Points
DO NOT use the towing/lashing eyes for recovery - that is not what they are designed for. You might get away with it but if it let go with tension on a tow/or winch rope the resulting whipback of the rope with the lashing eye attached could maim or kill you or someone else. I saw a picture of a Range Rover some time back that had attempted a recovery of another stuck truck, the recovery point failed and went through the rear screen, creased along the inside of the roof and then smashed the windscreen from the inside - it just missed the drivers head...........whatever you use must be up to the job and be attached to a strong piece of the chassis - you have been warned!!
I think the Big Jimny shoppe has a recovery point available for the front and a towbar should do at the back although a jaw on it rather than a loop of rope over the towball is preferable.....
Paul.
Paul.
- Johnniehec
- Thank you received: 56
20 May 2011 08:34 #16591
by Johnniehec
Replied by Johnniehec on topic Re: Front and Rear Recovery Points
Have a look back at ther topic "Recovery points" in the technical forum.
John.
John.
- Monkey
21 May 2011 07:28 #16635
by Monkey
Replied by Monkey on topic Re: Front and Rear Recovery Points
www.auszookers.com/index.php?name=Forums...torder=asc&start=630
Click on the link and see what can happen when use the rear "tie-down points". :blink:
