Todays Job - KingPin Bearings (1st timer)!
  • Andy
05 Apr 2011 07:02 #14505 by Andy
Well, after Martin kindly sent me all the bits to do the job...they have sat and stared at me every time i've went into my garage for this and that. Day off today however...so here goes nothing...
:whistle:
  • vitara_mad
05 Apr 2011 07:21 #14506 by vitara_mad
Replied by vitara_mad on topic Re: Todays Job - KingPin Bearings (1st timer)!
its a easy job to do as im sure you will find out soon enough
05 Apr 2011 07:25 #14507 by mcjimny
Once you've done it you'll wonder why you worried about it!
Only bit of advice is, to get the race out if you don't have access to a welder like shown in martins guide use a small punch or small cold chisel to tap round the small edge you can get on to. it is only a small lip but its enough to tap them out.
I've managed to do it without taking the joint apart and just hinging the swivel out of the way.
05 Apr 2011 17:51 #14542 by kirkynut
mcjimny wrote: Once you've done it you'll wonder why you worried about it!
I used a suitably sized socket on an extention bar to knock the race out.
How did you find getting the shaft back in the diff without taking the joint apart - I'd not thought about it as being possible but then hadn't tried.
  • Andy
05 Apr 2011 19:28 #14557 by Andy
Well both side went pretty well I guess, considering it was my first time...and probably the biggest job I've done on it yet. Wasn't full of yuck though like pictured in Martin's guide. (thankfully!) whilst on the subject- many thanks again to Martin for his guides; the confidence they give to just get the tools out and get a new unfamiliar job like that done is priceless. :) Thanks also to mcjimny, round punch did the trick with the bearing race :)
  • bertbuckie
05 Apr 2011 19:44 #14559 by bertbuckie
Replied by bertbuckie on topic Re: Todays Job - KingPin Bearings (1st timer)!
lol, I thought by the timeline difference from starting to this youd failed...... glad you idnt :)
Bert
Time to create page: 0.725 seconds
