Hydraulic lifters/lash adjusters
24 Oct 2018 23:05 #197013
Hydraulic lifters/lash adjusters was created by helijohn
What is the best additive to use to try to quieten noisy hydraulic lifter(s)?
- Max Headroom
- Banned
- Thank you received: 217
25 Oct 2018 02:53 - 25 Oct 2018 03:00 #197018
by Max Headroom
Replied by Max Headroom on topic Hydraulic lifters/lash adjusters
My wife and I had a noisy Vauxhall Meriva sometime back, which became very noticeably quieter after I switched to fully synthetic engine oil - I was astonished at how smoother and quieter it became.
However... this is not helpful if you are already using fully synthetic oil and you would need to consider the viscosity of (usually) thinner synthetic oil.
Moreover is the Jimny engine suited to fully synthetic oil? A lot of main dealers still seem to use semi synthetic.
A different situation but possibly of interest, the vintage cars I'm involved with, don't like synthetic oil as it is too thin for the plain bearings these engines have, as well as the larger tolerances and so tend to leak.
Some people use Castor based oil (which smells great) such as "Castrol R" but this is also known to leave gummy residue in components like piston rings. Castor oil is known for its use in stunt aircraft because when the engine is inverted or subjected to negative g-forces the oil can easily drain away from important components and castor maintains a wet residue long after supply loss.
Slick50 perhaps?
There are however many arguments that oil additives are nothing more than 'snake-oil'
If your engine is 'tappety' then putting something 'gloopy' in there may quieten it down, but something else might suffer, possibly the oil pump in having to shift treacle. Hiding the symptoms of a problem, doesn't necessarily fix the problem.
Sorry if my reply is a bit gloomy
Slick50 perhaps?
Last edit: 25 Oct 2018 03:00 by Max Headroom.
25 Oct 2018 06:30 #197019
by sniper
Replied by sniper on topic Hydraulic lifters/lash adjusters
I changed to Mobil One and I can't say I noticed the valve train getting quieter but it did improve the VVT. Much more noticeable as it comes in and you do get a bit of a surge from it, not much...... but something has improved and thats all valve train related.
For the extra cost, £40 more over a years motoring, I would suggest you try it.
sniper
sniper
- Thank you received: 1983
25 Oct 2018 07:07 #197021
Replied by Lambert on topic Hydraulic lifters/lash adjusters
I use carlube C3 5w30 in ours and they're all very quiet.
25 Oct 2018 08:12 - 26 Oct 2018 11:15 #197025
Replied by helijohn on topic Hydraulic lifters/lash adjusters
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configuration
I don't know what was in the engine when I got it; it was black when I drained it and the garage told me they had put in new oil the day before it was delivered (it was black then) but the book of words states 5w30 so I recently put it in and oh dear it all got a lot worse. The book also says 10w30 but I didn't have that lying around so I used 10w40 and it got better to the point of how it was in the start with just one tappet ticking. The other 23 seem fine.
10w30 is not easy to find. Carlube do 10w30, I found it online but I am not sure if it is the hot end (SAE30 or even 40) of the spectrum that I need or the low end (10W). I'd hate to put in a 10w30 and get the awful tappet noise again.
I personally think 5w30 is partly recommended to aid in achieving good mpg which is great in a new engine. This motor has done 80K and is 20 years old! Having said that the 5w was charted for really cold climate starting and 10w for not so cold regions; in this climate 10w is right according to the manual.
It's a lot of money down the drain if I use this
or
and the tappety noise gets worse (like it was embarrassing to drive) and then have to change it- :blush:
Fully synth is harder to source in 10w30 whereas 10w40 is available and cheaper.
The main thing is I was wondering what additive to use to clean out the hydraulic lash adjuster and what oil to put in after an oil change.
Lambert wrote: I use carlube C3 5w30 in ours and they're all very quiet.
or
Last edit: 26 Oct 2018 11:15 by mlines. Reason: test edit
25 Oct 2018 16:05 #197044
Hmmm. Thing is Ermintrude has always had c3 from new and is now at 84k and as quiet as Zebedee on 23k. I think that personally I'd be looking beyond the oil for the root of the problem and addressing that. It's not like it's an old ford cvh that is almost designed to rattle to the point of sending you mad. I know that replacement of lifters isn't exactly a 10 minutes diy job but I'd be investigating none the less.
