Can anybody help with an Alfa problem?
  • 1066Boy
30 Dec 2015 18:19 #159355 by 1066Boy
Evening fellow members. I have a small issue with my Alfa 159 and wondered if anybody
on here has an idea how to fix it. Have tried the Alfa forum but its not the friendly place the
Jimny one is. ;)
Drivers side rear door is stuck closed as if its locked. Outside and inside handles feel normal
( ie still attached.) Any ideas? Regards Allan. :)
  • S Mark
30 Dec 2015 19:31 #159359 by S Mark
Replied by S Mark on topic Can anybody help with an Alfa problem?
I assume there is nothing stuck in the door like the seatbelt or jumper ECT, Did you have child lock on the last time you shut the door? If not it might be worth giving the inside of the door a good sturdy wack over and over wile locking and unlocking the central locking. You can sometimes get some grit in the greece they put on the mechanism when serviced, if you get it open give it a good soak with WD 40, if you have the time it might be worth taking the door card off before closing the door and use a screwdriver to close the latch to make sure the mechanism works properly before.
I hope this helps
  • 1066Boy
31 Dec 2015 07:29 #159395 by 1066Boy
Replied by 1066Boy on topic Can anybody help with an Alfa problem?
Thanks mate. I will have a investigation at the weekend. :)
  • 1066Boy
14 Jan 2016 07:11 #160310 by 1066Boy
Problem solved! Swapped the Alfa for a Honda Civic Type s GT. :laugh:
  • Daniel30
14 Jan 2016 08:12 #160316 by Daniel30
Replied by Daniel30 on topic Can anybody help with an Alfa problem?
That's that sorted then :woohoo: :woohoo: :woohoo:
Time to create page: 3.429 seconds
