muddy bottom 4x4 newforest advise
- idiotmobil
09 Nov 2013 09:32 #90080
by idiotmobil
Replied by idiotmobil on topic muddy bottom 4x4 newforest advise
Slindon and boxgrove are about 25 miles so quite close thinkbthat will be thesites I go to
10 Nov 2013 08:26 - 10 Nov 2013 08:36 #90166
by kirkynut
Replied by kirkynut on topic muddy bottom 4x4 newforest advise
Slindon is very good. It has bits for everyone and is massive. Have a drive around the access tracks and get out for a walk on your first time to see what's what, then start to have a go at some of the tracks off the access tracks and build yourself up.
Just walk each one first and be aware that with no lift even small ruts will see you grounded out on your diffs, radius arms and radius arm mounts. The ground is largely sandy but can be very hard and clay like. Trust me, I've tried putting tent pegs into it!
If you are new to offroading, before trying any of the big hills, read up on how to deal with failed hill climbs, such as putting it in reverse and bringing the clutch up to let it down under engine braking whilst steering it down straight. If you stalled, leave it stalled as it will start as if being bump started on the way down.
If you stall it just trying to drive over an obstacle you will have found that the standard Jimny transfer box low ratios are not that low. It may not want to start and may just turn over. Don't panic, it's not broken, Jimnys are like that. Give it full throttle to let more air in and once it catches let your foot off the throttle. If is still won't start, don't run your battery flat trying, just give it a minute and try again. It will start. It floods for some reason.
I read of others on here going to Slindon. Perhaps you could hook up with them and have them show you round. It's a bit far for me I'm afraid.
Last edit: 10 Nov 2013 08:36 by kirkynut.
- idiotmobil
10 Nov 2013 10:32 #90176
by idiotmobil
cheers for the advise but not alot of it matters to be lol jimnys far from standered and should do ok ive done a fair bit of offroading through my life just never in my own jeep ive allway been in to my motocross and raced for years some off the lanes i drive are basicley byway play sites ill be checking out slindon is there a place i can find out dates and times
Time to create page: 3.302 seconds
