Re:My 01 Jimny, another Norwegian
- mdog18
- Visitor
- MadsV
- Visitor
- Thank you received: 333
They really should!MadsV wrote: New rear engine mount today
A bit messy with oil or something up there.
Mounted the castor correction bushes also
They really should come with the lift kit, its much better to drive, hardly any trailing compared to before!
Gearbox shaft seal leaking?
- MadsV
- Visitor
- MadsV
- Visitor
- MadsV
- Visitor
Hood and all cables off
Cleaned out the bell housing, was alot of oil spill there from the leaking engine. Pressure washed the rest of the engine bay.
Engines are on top dead center and ready to pull the cam sensor ring tomorrow.
Here are the two sumps, you can see that the small baleno one is wider than the jimny one. Cutting and welding them tomorrow! Hoping to maybe get it in the engine bay when saturday is over
- Thank you received: 1761
- MadsV
- Visitor
Been all over the city looking for a bearing, but the shops that could have it are closed on saturday, of course.
Guess I can take my time getting everything ready, have to patch some rust holes also at the front thats not reachable when the radiator is in.
Here is the blanking plate for the rear of the head. Original with a rubber seal, metal gasket on the Baleno G16B. Sealed a little bit with rtv silicone also
- OlaGB
- Visitor
Did you check the flywheel for wear, as it looked alittle worn on the pictures?
- MadsV
- Visitor
The clutch has had its days so I should consider changing the flywheel later on
- MadsV
- Visitor
- MadsV
- Visitor
