Wheel Alignment Benefits ??
- grumyoldjoe
- Elite Member
- Thank you received: 20
I declined especially as it would cost 60 notes, (then 40 after i said no )
My thoughts was "whats the point if ithe car is going to be on and off road over pot holes speed humps forest tracks and country lanes"
I can understand it if I was doing lots of motorway miles etc for wear and economy
Is there a benefit having it done a Jimny ??
TIA
Wine improves with age.
- mickt
- Visitor
- grumyoldjoe
- Elite Member
mickt wrote: Was it Kwik Fit by chance?
Twas indeed.
- Thank you received: 178
- Thank you received: 333
Put something white like chalk or paint on the center of the tire thread on the rear of the tire..
then take a piece of board or a piece of string with two nails in it to make mark on the white spots on your tire.
then roll the car forward so the mark comes to the front of the tire, then measure how much toe in you have from the difference between the two measurements..
Hmm did anyone understand this?
Take into consideration that you might not get to measure on the complete opposite diametrical places.
anyways it could help to have a bit more toe in if you have changed to bigger tires. The manual says 2-6mm with standard tires. On my SJ with 31" i had 10-12mm wich reduced the wobble.
- mickt
- Visitor
- Max Headroom
- Banned
- Thank you received: 217
Heheh - yes, actually. Though I got a bit concerned when it got to the bit about nailing some wood to the tyres
And thats a +1 from me regarding mickt's impression of Kwik Fit
- grumyoldjoe
- Elite Member
A family friend recently got charged for an aircon repair for aircon the car is not fitted with from a national franchise. She didn't understand the technical rubbish they spoke of about compressors and condensers.
Find one you trust and go to them, even if they are £5 more per tyre. Use them or lose them and be stuck with the rubbish ones.
- Thank you received: 653
Then proceeded to go get it tracked 40 quid 60 quid I said I only want it tracked lol
new ends nothing hard to adjust ........
Ended up at local ATS euro master....WINNER 25 quid....
Jack
