suspension.
- jonesyba420
- Visitor
basically when my dad got his defender it had a 2inch lift but he decided it wasnt needed for what he uses it for so put it back on standard length springs but kept the longer shocks and brake lines. in theory keeping the advantages of more shock travel ie more droop etc but without the hassle of a lift, ruined caster excessive wear on joints etc.
im thinking of doing the same thing to my jimny as i currently have no intention of fitting bigger tyres but wouldnt mind improving the jimny's capabilities and ride offroad.
so i would fit: +2" shocks either the rough country n2.0 or procomp es1000's (views and opinions on which shocks are better are definately welcome), extended brake lines as i have no ARB and rear shock relocators (if i fit these do i then need to extend the front shocks as the rears will be longer?) and maybe some spring clamps incase of spring dislocation.
has anyone tried a setup like this?what are peoples views?would i have problems regarding upwards travel or is that limited by the spring and bump stops??probably the most important question IS IT WORTH DOING?
im not planning on doing it tomorrow just something ive been thinking about and i cant really think of any disadvantages.
- Thank you received: 1763
- jonesyba420
- Visitor
- TomDK
- Visitor
Some users on this forum believe that shocks for offroad needs to be as soft as possible, which is as wrong as it can be. Try go just a little fast over bumps and such, and your shocks will easily bottom out. You'll want shocks that are hard enough to take a beating, without bottoming out all the time. Even more so, if you have a winch fitted.
Fitting longer shocks it self will limit up-travel and extend down-travel. So you usually fit longer/harder springs that will match the shocks. At least on the suspension-kits most users can afford.
- Dave cc
- Visitor
- jonesyba420
- Visitor
think the jimny is a pretty hard ride anyway probably to hard for comfort offroad you feel every stone.
arnt the Es9000 for heavy trucks? With Winches etc.
I would be getting them from here so maybe martin can offer some assistance.
- JuanGuillie
- Visitor
TomDK wrote: The Rough Country N2.0 shocks are far better for offroading, as they are much harder shocks.
+1
My first set of shocks and springs were OldManEmu and the blue MAD springs, this was about 1 inch lift.
For me it was too soft and certainly at "higher" speed on mudtracks, if you did feel it going sideway's it was almost too late.
I did change them after 1 year to the complete Trailmaster Stage II "Sport" 2 inch kit (shocks, springs, corrector bushes and steering dampener).
This "Sport" configuration is stiffer then the "Comfort" set, it did cost me some money but i feel save with this set-up!
Still feeling very happy with them, even with my rear shock relocaters i still have enough space for the shock to go completely in and out without "bottoming", even at higher speed !
Having a winch in the front then put the "Diesel" Trailmaster Stage II Sport set.
- TomDK
- Visitor
Dave cc wrote: Im running ES9000 pin pin on both my trucks soft works just fine for me
ES9000 are probably some of the hardest shocks available to the Jimny in this price range. They harder than RC N2.0.
- TomDK
- Visitor
Shocks with various stages of daming are very expensive.
Like Fox or King Triple Bypass shocks. They easily cost £6-800 each.
- Dave cc
- Visitor
- GuardianAngel
- Visitor
If your not planning to fit bigger tyres when why do you want to lift it by 2"? Not wishing to teach you suck eggs, but your still going to have the lowest point of the Jimny at the same height unless bigger tyres are fitted, i.e. the diff case.
But, as I said, I might be missing something....
