Clutch and fitting procedure
- jimnydms
- Visitor
any recommendations for a stronger than OEM clutch as i imagine the OEM clutch is not up for the job on big tyres lift crawler box and winching etc
any thoughts welcome please
can this be done from underneath? its on 235's and i got some big ramps to drive the front on to.
anythink i should look out for? procedure etc
cheers
- toph
- Visitor
If you have option of getting some one to do it for you I would let them loose the skin on the backs of their hand and bang their hand on the transfer box.
- jimnydms
- Visitor
- markyp2000
- Visitor
www.rhinorays.co.uk see what he says
i did mine on my back didnt need to jack it up as i have a 4.5" lift what can i say never again one tip i can give you if you do it and its a single cam engine when you fit the clutch dont tighten the clutch bolt right up leave them loose so the plate just moves fit the gear box then where the clutch cable go on the fork you can get to the bolts only reason i did this was due to there being to studs on the engine and it stops you from twisting want wiggling the box up and down to get it on the splins if they are not ligned up good luck and enjoy
- jimnydms
- Visitor
any thought s on what clutch, OEM or any uprated 4x4 clutch ?
- markyp2000
- Visitor
- Basketcase
- Thank you received: 51
- toph
- Visitor
jimnydms wrote: great lol was the answer i was half expecting. what clutch did you fit?
I took out a paddle clutch which was too harsh for greenlaning and replaced it with an exeddy normal one.
- jimnydms
- Visitor
you ve found the exeedy one ok lasts ok and handles off road punishment ?
- Thank you received: 116
toph wrote: Quite possibly the single most pain in the ass job I have done on my jimny!
I quite AGREE - after messing around underneath and EVENTUALLY getting it fitted, i decided the NEXT time that I would:
a) Pay someone else to do it
b) Consider taking the engine out!
But will probably just do option a).
Jalapeño, IISY?
- markyp2000
- Visitor
- VAXXi
- Visitor
