BigJimnyMeet 2024
× A place for more technical discussions. Please make sure you post in the correct section on the site, this way it keeps the site tidy AND ensures you get a more relevant answer.
front axle binding
  • adamjimny
  • Visitor
  • Visitor
11 Mar 2012 16:18 - 11 Mar 2012 16:20 #35281 by adamjimny
front axle binding was created by adamjimny
iv got a problem with the front axle that it locks up and stops forward movement but its okay in reverse.
iv narrowed it down to
  1. drive shaft broken
  2. diff busted
  3. crown and pinion got some debris in teeth
does anybody know whats happening or had any similar problems as i want it fixed asap then i can get an MOT booked
Last edit: 11 Mar 2012 16:20 by adamjimny.
  • Paul4x4
  • Visitor
  • Visitor
11 Mar 2012 16:41 #35284 by Paul4x4
Replied by Paul4x4 on topic Re: front axle binding
Sounds like a busted CV joint to me.
  • adamjimny
  • Visitor
  • Visitor
11 Mar 2012 16:53 #35285 by adamjimny
Replied by adamjimny on topic Re: front axle binding
its not when turning
i can move 5 meters or so then it just locks
if it was a cv surely it would be constant and when under pressure?
  • Paul4x4
  • Visitor
  • Visitor
11 Mar 2012 16:55 #35286 by Paul4x4
It still sounds like a cv to me.:laugh:
  • adamjimny
  • Visitor
  • Visitor
11 Mar 2012 16:59 #35288 by adamjimny
how can you tell if they have gone as they seemed fine when i had them out or can they be knackered and still seem fine?
  • Paul4x4
  • Visitor
  • Visitor
11 Mar 2012 17:11 #35291 by Paul4x4
adamjimny wrote: how can you tell if they have gone as they seemed fine when i had them out or can they be knackered and still seem fine?
The one that would be causing the problem you're having, would more likely have seemed to be in pieces than fine.:laugh:
If you have inspected them after the binding occurred, and they looked fine, then they sure aren't causing that.
Once my wheel bearings went on one side of my SJ's front axle, and that caused similar problems. But I don't think broken shafts or diff could cause that...
  • adamjimny
  • Visitor
  • Visitor
11 Mar 2012 17:15 #35293 by adamjimny
no worries ill check them again :pinch:
11 Mar 2012 21:23 #35321 by facade
Replied by facade on topic Re: front axle binding
Make sure the hubs are free, and nothing inside the axle can bind, as nothing goes round in 2wd. The MOT doesn't use 4wd so you don't need fix it before.
If it is still binding and the hubs are free and it is in 2wd you have a big problem.
  • adamjimny
  • Visitor
  • Visitor
12 Mar 2012 14:02 #35355 by adamjimny
facade wrote: Make sure the hubs are free, and nothing inside the axle can bind, as nothing goes round in 2wd. The MOT doesn't use 4wd so you don't need fix it before.
i know this but i have locked hubs so it all turns even when in 2wd all rotates smoothly then just binds.....really weird
  • adamjimny
  • Visitor
  • Visitor
14 Mar 2012 21:14 #35563 by adamjimny
Checked and both cv's are like new and had a detailed feel and its something not 100% in the diff soo what could cause this problem in the diff?
Sent from my GT-I9100 using Tapatalk
14 Mar 2012 22:02 #35575 by supergaz
Replied by supergaz on topic Re: front axle binding
Failed bearing in the diff? Sounds like you will need to pull it out.
  • adamjimny
  • Visitor
  • Visitor
14 Mar 2012 22:39 #35576 by adamjimny
Yeah im thinking that or debris gettin trapped in ring n pinion.....hoping for the latter
Time to create page: 0.123 seconds
Powered by Kunena Forum
