Jimny Diff ratios
- fordy103
- Visitor
So, anything newer than 2006 has better diffs than the old ones. ( for off roading anyways)
Can anybody confirm this?
James
- Thank you received: 34
Former owner of Little "Ooky", who has now started a new life in Shetland
- dadam
- Visitor
- dadam
- Visitor
i'm really tired actually, sorry...mlines wrote: So you need to look at the final line in that table that ook123 linked to....
- panosd
- Visitor
You can run tires 235-75-15 with no problem.
It wont be like having a rocklobster but it will seems like a mini rocklobster(410 t-case).
It is tested and works great.
Also you can find from japan spec. jimny with 11/45 diff ratio and do the same.
- frede.gv1
- Visitor
sorry for spelling:sick:
- TomDK
- Visitor
panosd wrote: If you change the r&p of a non vvt jimny with the r&p of a vvt jimny you will have a -17% low ratio.
So, if having a 2002 non-VVT, I can install VVT ring&pinion gears into my diffs and get a -17% reduction? Or is it the other way around ?
- Thank you received: 584
When we say "lower gear ratio", we actually mean higher to go slower!
- Monkey
- Visitor
- frede.gv1
- Visitor
- Monkey
- Visitor
