BigJimnyMeet 2024
× A place for more technical discussions. Please make sure you post in the correct section on the site, this way it keeps the site tidy AND ensures you get a more relevant answer.
Spotlight relay wiring help
28 Apr 2011 17:53 #15605 by mlines
Your diagram is correct Alan based on my understanding of relay numbering.
Renard has posted the same and shows the "Trigger" feed going to the headlamp via a switch on the dashboard.
The following user(s) said Thank You: coptleigh
  • coptleigh
  • Visitor
  • Visitor
28 Apr 2011 18:06 #15607 by coptleigh
Replied by coptleigh on topic Re: Spotlight relay wiring help
POOH
Just had a go at wiring up the relay as shown, still not working, checked the wiring and only possible explanation is the link to the main beam circuit, I tapped into it near the bulb holder, is this OK. done it before and all OK on other cars, but am I using the right wire, from what I can see from the wiring diagram, I used the mainly solid red wire??? is this the one>> or one of the other two, or should I pick up the feed from somewhere else?
Alan
  • coptleigh
  • Visitor
  • Visitor
29 Apr 2011 16:12 #15635 by coptleigh
Wired up and working fine , so thanks to all for help and advice.
Cheers
Alan
PS How does the steering wheel middle cover come off so I can check the horn buttons??
  • Back in Black
  • Visitor
  • Visitor
23 Dec 2011 14:13 #29055 by Back in Black
Replied by Back in Black on topic Re: Spotlight relay wiring help
Excellent diagram - spot lights wired up and working!!
Angel eyes (LED outer ring) wired to side lights, main spots wired to main beam ;)
Thank you
23 Dec 2011 16:48 #29076 by dirtydogz
I think renard38@coptleigh need a big thank you, for their drawings, it's so simple to work out.
Attachment neg2pos_2011-12-23.gif not found
Attachment DSCF1638_2011-12-23.JPG not found
I've just add one wire to the drawing to light up the switch
DIRTYDOGZ
2002 JLX Soft Top B)
Jimnybits 2" lift +Pro Comp ES1000 shocks.:) Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
  • Back in Black
  • Visitor
  • Visitor
24 Dec 2011 08:00 #29144 by Back in Black
Sorry, it was Renards drawing I followed. Until I found that I was in the dark (literally) ;)
Now if only I could fix my reversing lights!!
  • ne-crock
  • Visitor
  • Visitor
05 Sep 2012 23:15 #47617 by ne-crock
Replied by ne-crock on topic Spotlight relay wiring help
sorry to bump this thread up but,
i want to wire mine in with a switch to be able to have them sperate to my high beams,
dirtydogz i noticed you said your photo had a extra wire added,
but the photo doesnt work for me,
any chance you could pm me it?
  • Barry
  • Visitor
  • Visitor
18 Dec 2017 13:34 - 18 Dec 2017 15:11 #187596 by Barry
Replied by Barry on topic Spotlight relay wiring help
Can someone please explain this? I was just about to wire in two spotlights, and found the feed to the main beam lights are neutral-switched! I've put the spotlight relay in, and wired up:
85 to neutral (earth)
30 to permanent live
87 to spotlights
So where does 86 go?
30 and 87 is the switched part, and 85 and 86 is (usually) the coil part, but the neutral switching has me completely stumped.
Last edit: 18 Dec 2017 15:11 by Barry.
18 Dec 2017 16:16 #187602 by X8GGY
The following user(s) said Thank You: Barry
  • Riccy
  • Riccy's Avatar
  • Banned
  • Banned
  • J999 MNY Bashing around Carlisle
18 Dec 2017 18:03 #187604 by Riccy
Replied by Riccy on topic Spotlight relay wiring help
86 needs to be a live by elimination
the coil needs a + and a - to work, what it switches is irrelevant as long as its within its current abilities (can switch on neg or pos as you want).
  • Barry
  • Visitor
  • Visitor
20 Dec 2017 12:49 #187665 by Barry
Thanks, everyone. All done. Got some strange (to me) readings from my multimeter when trying to figure out the lamp wiring -
14 volts from two of them, and 1.5 from one (not zero) with mainbeams on. Anyways, just to make it crystal clear for anyone else:
Live
Fuse
30 AND 86 on relay
87 out to spotlights
85 spliced into mainbeam wire where it goes into 3-pin plug. It's the primarily red wire nearest to the wing on the driver's side.
  • Teggy
  • Visitor
  • Visitor
18 Feb 2019 21:01 #203421 by Teggy
Replied by Teggy on topic Spotlight relay wiring help
Barry wrote: Thanks, everyone. All done. Got some strange (to me) readings from my multimeter when trying to figure out the lamp wiring -
Live
Fuse
30 AND 86 on relay
Hi guys. newbie here and just found out about Suzuki's strange headlight wiring .. any way .. my son has mounted some spots in the bumper and we're powering via a relay which we could not get to work correctly .. spots permanently on regardless of headlight operation.
Then. I found this which I have followed, but still have a small problem in that when you switch to high beam, the spots come on, but do not turn back off when you return to dipped !! they will only turn off when you turn off to sidelights only.
Hoping this "HOLY THREAD REVIVAL BATMAN" will summon someone who knows.
Cheers Daz
Time to create page: 0.149 seconds
Powered by Kunena Forum
