BigJimnyMeet 2024
What comes standard and what should I fit after-market?
- StevenMark
- Visitor
30 Jul 2018 00:53 #194705
by StevenMark
What comes standard and what should I fit after-market? was created by StevenMark
Hi there
Absolute beginner here. I live in Auckland and am considering joining a 4x4 club with my son as a father-son bonding thing
I am in two minds about either buying a SWB 4x4 and use and external tent or purchase a LWB 4x4 and sleep in the back.
Anyway - if I do go with the SWB 4x4 I have decided that a Jimny-Manual-Petrol is the vehicle I want.
So as you can guess I am doing LOTS of research ... and what I have found is that in order to be effective a 4x4 vehicle needs the following:
1] Good clearance
2] Good approach and departure angles
4] Hi-Lo range
5] Lockable hubs (rear vs front is debatable - some suggest having both)
So I believe that the Jimny has the first 4 as stock (I am open to correction on this) ... but I am not sure if point 5 is something I need to have done after-the-fact? I tried to Google it but all the results talk about "Locking diffs" .. and I can't seem to find a straight answer about hubs vs diffs. Basically there needs to be way to A] Send power to both axles but keep the wheels on either axle turning independently (aka 4WD) and B] When needed - Make sure that the wheels on any particular axle are locked together so that they turn at the same rotation (Lockable hubs? -- need to be fitted after-market) - and then turn this off again when out of trouble and continue on my way - but stay in 4WD
Sorry if I am not explaining it properly
Any help will be appreciated.
Thanks
1] Good clearance
4] Hi-Lo range
Thanks
- Thank you received: 1761
30 Jul 2018 04:23 - 30 Jul 2018 04:25 #194707
Replied by Lambert on topic What comes standard and what should I fit after-market?
Welcome to the forum. Ok so you're on the right track but the bits you're confusing are hubs and differentials. Locking hubs are not a traction aid, they're a means of disengagement of normally the front wheels when on high grip surfaces. This is to save fuel and wear and tear on the front axle components and drive line. They are a function of the normal operations of some part time 4x4 systems.
Locking differentials are a traction aid. They facilitate removing the ability of one or more wheels to spin relative to the other wheel on the axle, meaning that if one wheel has traction the vehicle will attempt to move. Locking differentials go in either axle and in permanent 4x4 systems in the centre between the axles in the transfer box too and depending on which are fitted and engaged allow all wheels to turn at the same speed, great off road but will significantly affect the turning of the vehicle and shouldn't be engaged on high grip surfaces for risk of damaging the drive line.
A Jimny doesn't have any locking diffs as standard but they are available. A Jimny does have locking front hubs which are operated by vacuum and are notoriously fragile they are however replaceable with a much more reliable manual version.
Last edit: 30 Jul 2018 04:25 by Lambert.
The following user(s) said Thank You: StevenMark
- Thank you received: 178
30 Jul 2018 04:30 #194708
by gv42
Replied by gv42 on topic What comes standard and what should I fit after-market?
welcome to the forum
- Thank you received: 320
30 Jul 2018 09:18 #194713
by Gadget
Replied by Gadget on topic What comes standard and what should I fit after-market?
The Jimny comes with locking front hubs, which part-time 4wd vehicles (like the Jimny and series land rovers) use to engage their front wheels when in 4wd mode.
The Jimny doesn't come with locking diffs, which force each wheel on an axle to rotate at the same speed, preventing you from being cross-axled with one wheel spinning uselessly in the air while the other side doesn't move.
- Thank you received: 260
30 Jul 2018 23:18 #194726
Replied by helijohn on topic What comes standard and what should I fit after-market?
Hello there and welcome.
I think you'll find the Jimny is a competent vehicle enough to get in and just do it.
31 Jul 2018 20:24 #194744
by kirkynut
Replied by kirkynut on topic What comes standard and what should I fit after-market?
Welcome along.
So hubs and diffs have been explained. You don't need locking diffs straight away. I don't have them and have rarely found the need.
A suspension lift and bigger tyres with a Rocklobster transfer box to reduce the ratios, along with a winch in a winch bumper and a decent rear bumper are what's needed. Perhaps an external roll cage too.
I've just described my Jimny. Look at my thread in my signature.
31 Jul 2018 20:56 - 31 Jul 2018 20:58 #194747
by Bosanek
Replied by Bosanek on topic What comes standard and what should I fit after-market?
If you desire a no-compromise off-road vehicle which has got it all and much more than that, then the only things available a a factory standard issue are Mercedes G class and Jeep Wrangler Rubicon. There is also Toyota Land Cruiser 70 SWB with both lockable differentials, but (as far as I know) those are available only to desert sheiks (literally - only in the Arab peninsula).
All of these vehicles, if in good condition, cost like a nice little village house.
Jimny is not far away from those three regarding off road capability, and can be upgraded (at a significant cost) to match them. Regarding pure robustness and quality, well, it can never match them. But it costs 5-30 times less to buy.
If you come to the point of buying a Jimny, read this wiki article first .
Last edit: 31 Jul 2018 20:58 by Bosanek.
- TomDK
- Visitor
01 Aug 2018 21:00 #194771
by TomDK
Replied by TomDK on topic What comes standard and what should I fit after-market?
The 70 series cruisers are available in a wide range of models. Troopers, pickups and others versions. Both long and short wheelbase. But lwb is by far the most common.
Still very popular in Australia, Asia and the middle East. Not long ago I saw a newer model here in Denmark, ready to be shipped to Greenland.
- Venter
- Visitor
02 Aug 2018 12:59 #194786
by Venter
Replied by Venter on topic What comes standard and what should I fit after-market?
LC 70 series are massively popular in Australia, and also across the whole of Africa. I'm sure they'll be easily available in New Zealand too. Note that it (surprisingly) does not have diff-lock as standard in a lot of the markets in which it is sold.
But if you're just after an introductory 4x4 to have a bit of fun in and in which to learn a lot, the a Jimny would fit the bill. Go with what Kirkynut said, in the following order (1) bigger tyres, (2) suspension lift, (3) lower ratio transfer box. Everything else can come after these three items once you've got a better feel for things. Diff lock at too early a stage can also impede the progress of your learning, as it makes a lot of things too easy. Learn how to get past things with open diffs first!
- StevenMark
- Visitor
04 Aug 2018 07:47 #194822
by StevenMark
Replied by StevenMark on topic What comes standard and what should I fit after-market?
I see that you never included Pajero in that list. Was that on purpose? I only ask because that has been recommend to me too. Thanks
- TomDK
- Visitor
04 Aug 2018 08:38 - 04 Aug 2018 08:41 #194823
by TomDK
The pajero is very much like the land cruiser Prado and other more civilized 4x4s with independent front suspension and drives more or less like a normal car. Pajero just doesn't have the reputation of toughness and quality that land cruisers do.
You could probably call the Pajero a hairdressers 4x4
Last edit: 04 Aug 2018 08:41 by TomDK.
10 Aug 2018 09:48 #194969
by Busta
Replied by Busta on topic What comes standard and what should I fit after-market?
A standard Jimny with slightly larger 215/75r15 tyres and a rear diff locker is a match for any 4x4 on the market. The downside of a Suzuki is always their lack of clearance in deep ruts. But normally on Australian trails there is a 'Suzuki line'- a route around a tough obstacle that favours the small size and nimbleness of a Suzuki, where other 4x4s simply don't fit. I had a GQ Patrol in Oz, but if I was to spend time over there again I would definitely be getting a Jimny.
